Pulling Throttle cable
5 replies to this topic
  • mightymart
Posted January 19, 2008 - 04:29 PM
Amazing I was gone riding tomorrow & here I am at 22mins past midnight trying to fit new handlebars :cool:
I have read about the cables going below the tank bolts but I have checked this & they are above, Is there any reason why I can't turn the throttle grip upside down to give me a little more slack ? the picture below is how it was & want to turn the throttle grip round 180 so the cables would be below ?
Aslo is there a torque setting for the tank bolts ???
  • Old Dog
Posted January 19, 2008 - 05:19 PM
Is that the stock throttle housing or is it an aftermarket one? It looks like it might be a Motion Pro setup, but it's hard to tell from the pic. When I installed my Eddy I went with a Motion Pro quick turn ratio setup instead of the garbage stock one. I ran my cables behind the bars and then over the top of the engine (between the top engine mount brackets) then straight to the carb. This was the best way I found to keep them totally bind free through the whole turning radius. :busted: :cool: :applause:
  • XR4DEZ
Posted January 19, 2008 - 06:10 PM
Mine is rotated towards the pilot 90 degrees.
  • Krannie McKranface
Posted January 19, 2008 - 06:24 PM
+1
Don't point the top of the throttle up: the cables will snag on stuff, and the throttle will die if you crash on it. And you get less slack.........
  • Descalzo
Posted January 20, 2008 - 03:13 AM
+ 2 on that
  • mightymart
Posted January 20, 2008 - 09:34 AM
The only way I could do it was to turn it 180, if I only turned it 90 it was getting snagged, But to add to misery got it all set up ,handlebars , levers , mirrors, etc, then as i turned hard right it cut out :crazy: The decompresion cable was now stretching , Off come the mirrors & levers , reroute the clutch & decompression cable , At last done ! :prof: But its pitch black out now :cool: :applause: :busted:
