XR's Only case saver question
7 replies to this topic
  • bcass77
Posted January 18, 2008 - 05:11 PM
First post... question. I just got a new '05 650R and I just installed the XR's Only case saver. The instructions seemed a bit vague and I just want to make sure I did this right.
For those of you who have this case saver, is this how you installed it? I'm not positive I put this washer on the correct side of the engine. It was originally on the right side but it seems like it needs to be on the left side as I have installed it in the picture. I tried installing the case saver, leaving the washer on the right side and it didn't line up to well. Just double checkin. Thanks! Brian
  • XR4DEZ
Posted January 18, 2008 - 07:41 PM
I had to check mine I did it about 4 yrs. ago and it's the same as yours.
  • philipstjohn
Posted January 18, 2008 - 08:00 PM
I had to check mine as well, and it is the same as pictured, but as I remember when tightening down the top "cage bolt" it seemed to want to bow in. I believe I placed a couple of small washers inside the resessed area in the back of the Case saver on that top bolt so when it was tightened it would line up better and not bow in. :cool:
  • XR4DEZ
Posted January 18, 2008 - 09:13 PM
I don't use the cover, don't know why must be an old guy thing.
  • bcass77
Posted January 18, 2008 - 09:22 PM
Thanks for the replies! That's the same thing I was thinking.
  • Billahjack
Posted January 19, 2008 - 10:47 AM
I used a thinner washer from a aftermarket hardware kit. The thick washer bends the case saver out slightly on the 2 bikes that I have installed them on.
  • slowxr
Posted January 19, 2008 - 05:23 PM
hmmmmmm, I just checked mine and it's on the other side!
  • bcass77
Posted January 19, 2008 - 06:47 PM
I used a washer behind the top "cage bolt" as described below and it's perfect now. Thanks!
  • 3 replies
Honda XR650L 2016
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
Washington
  • Hot  32 replies
  • Hot  60 replies
