Anyone Use The Quickshots?
16 replies to this topic
  • YZF831
Posted January 18, 2008 - 02:19 PM
Just wondering how many out there are running the quickshots on your carb? I see Boyesen makes two versions and the first one is quite a bit cheaper than the new one now, are they that much better? Thinking of putting one on my 08. Any info helps. Thanks!!:cool:
  • WB450
Posted January 18, 2008 - 02:29 PM
I just picked one up on Ebay, I hope they work.
Posted January 18, 2008 - 02:34 PM
Try not to be too disappointed.
  • Dveitch8
Posted January 18, 2008 - 03:28 PM
I felt a huge difference with the throttle response especially off idle, eliminated the ridiculous amount of bog. :cool:
  • Dveitch8
Posted January 18, 2008 - 03:29 PM
that was with the quickshot 2 by the way
  • YZfamily
Posted January 18, 2008 - 08:57 PM
happy with mine so far, no more stalling when engine is hot.
  • Ga426owner
Posted January 19, 2008 - 09:23 AM
I have one ...it only addresses part of the issue....
I bought it when they first came out and everyone raved about it....for the what they cost a better solution for just about the same amt of cash is the ZipTy Carb mod...it fixes the issue once and for all.:cool:
  • todds924
Posted January 19, 2008 - 04:16 PM
I tried one on my 06 and 08.......they are garbage!!!!! If you wan't one that bad.....send me a stock cover and i'll give you one free....plus shipping. In my opinion they are a bad deal even for free.
  • todds924
Posted January 19, 2008 - 04:18 PM
The o-ring mod or wiring the acc. pump works the best.
  • Dveitch8
Posted January 19, 2008 - 07:32 PM
how do you do either of these?
  • todds924
Posted January 19, 2008 - 08:41 PM
Do a search in the jetting forum. They show you both ways to do it.
  • HMMRDWN
Posted April 27, 2008 - 04:48 PM
Ok I looked I cant find either of these mods. Can someone post the link?
  • albertaguy
Posted April 27, 2008 - 07:07 PM
don't know the link but simply put you take off the throttle body plastic cover on the right side. There is a black plastic arm attached to the throttle cam (all one piece). It touches the accelarator pump adjustment screw. Take a small heavy oring and loop it over the two so they are connected together, or wire tie them. Has the same effect as putting in a heavier duty spring only way easier to do. Creates more of an instantaneous response between your twist of the throttle and the acc. pump - minimizes the hesitation. Cheap and easy to do and makes a big difference I think (never did mine just on it's own, did other mods as well so hard to say). Makes sense that it should help. Also I did use the quick shot 2 and thought it was very helpful. Don't know why but it really lessened the backfiring snap crackle pop on decel as well which was really bad stock. I found after the qs2 I could hold 3rd in corners easier and much more instant throttle response. I now use the r and d power bowl on my ktm and it is great. Who needs fuel injection when you have a finely tuned carb.
  • WB450
Posted April 28, 2008 - 07:09 AM
It's in here about half way down under "Fuel System".
http://www.thumperta...ad.php?t=447989
  • WB450
Posted April 28, 2008 - 07:11 AM
I decided to give it to a buddy for his b-day, I don't need one.
  • albertaguy
Posted April 28, 2008 - 09:17 AM
Anyone running the powerbowls on their yzf's? or is that just a good fix for the ktm's which don't have a leak jet. Makes a big difference on the ktm going from no leakjet to a fully adjustable one and with the jd jetting kit plus oring mod it is very very crisp and responsive. Getting back on my yzf now it feels a bit slow to respond when I used to think it was crisp. Just wondering if anyone has one on a 07-08 yzf 450 and what they thought.
Posted April 28, 2008 - 10:03 AM
Some reading on what leak jets are for, and how they work.
http://www.thumperta...330#post4415330
http://www.thumperta...966#post6081966
http://www.thumperta...344#post6091344
  • Hot  47 replies
  • 10 replies
  • Hot  30 replies
