Decompression lever stuck?
1 reply to this topic
  • dezurist
Posted January 17, 2008 - 09:44 AM
Hey guys,
I have a 04 YZ450F and upon my last ride this past fall, I go to start it one last time and I grab the decompression lever and its stuck? We were riding on a fairly muddy trail system all day and I just figured it had some gravel in the lever hinge area. After a thorough pressure wash it appears to be still stuck and I cannot depress the lever at all?
Any ideas?
Been riding for many years, but pretty green to the 4 stroke world.
Thanks for any help or suggestions.
  • SJMC_DON
Posted January 17, 2008 - 12:19 PM
Hey guys,
Any ideas?
1 of 2 things in my experience -
1. they (the cable) get water in them and on cold days will freeze but this does not sound like your problem.
2. The plunger will get "cocked" in the carb. Remove the cable from the carb.... be careful not to strip or cross thread the plastic nut on the end of the cable. Wiggle it around, remove it and inspect the o-ring. I think they suggest a VERY fine layer of lube on the o-ring when you re-install it.
Good Luck:ride:
