2008 pipe question
27 replies to this topic
  • bazuki54
Posted January 17, 2008 - 09:11 AM
I just bought a 2008 yz450f and it feels slow compared to the honda. Is the pipe to blame? if I were to put a DR.D system on would it come to life? The bike handles better than the honda.
  • Ga426owner
Posted January 17, 2008 - 09:44 AM
yes the 08 yami pipe is a POS. Ditch it and you will be much happier....:cool:
what year Honda are you coming from?
  • Bigcr
Posted January 17, 2008 - 09:46 AM
The Dr. D will definately help. Plus, it's a solid piece of hardware.
  • Wes Woodin
Posted January 17, 2008 - 09:58 AM
Wanna smoke a honda? Dr.D Pipe, R&D Powerbowl, jump a tooth on the rear sprocket, VP U4.2 fuel and UNI filter. Last ingredient.......... Hold the throttle wide open.:prof: :cool: :applause: :busted: :crazy: :p
Posted January 17, 2008 - 10:00 AM
Absolutely. Certainly. Definitely. Undeniably. Unequivocally. And yes. :cool:
  • erickdj
Posted January 17, 2008 - 10:52 AM
Wanna smoke a honda? Dr.D Pipe, ......... Hold the throttle wide open.:lol: :cool: :applause: :busted: :crazy: :worthy:
fixed...
all you really need is the Dr.D pipe and a good amount of throttle.:prof: :p :eek:
  • SXP
Posted January 17, 2008 - 12:15 PM
Wanna smoke a honda? Dr.D Pipe, R&D Powerbowl, jump a tooth on the rear sprocket, VP U4.2 fuel and UNI filter. Last ingredient.......... Hold the throttle wide open.:p :cool: :applause: :busted: :crazy: :eek:
What would happen if you did the same to the Honda?:prof:
Posted January 17, 2008 - 01:41 PM
What would happen if you did the same to the Honda?:cool:
The race gas works the same in either (you knew that). Likewise, the stock air filters are a little more restrictive than aftermarket units, so that's the same, too. The pipe won't help the Honda as much as the YZF because the Honda pipe doesn't suck as bad as the '08 YZF does.
Dropping the gearing won't improve acceleration versus another bike, or a stopwatch, and it certainly cuts off top speed. But it goes through the shorter gears faster, so it feels better.
The Powerbowl will do nothing to increase peak output since it doesn't modify any part of the fuel system that feeds into the main circuit underway. Not even they claim that.
But that was your point, more or less, right?
  • Scspringer912
Posted January 17, 2008 - 03:51 PM
what is all this talk about this R&D Powerbowl. send me a link or something about it.. i never heard of it.. whats it do to the carb? or is it not even for the carb
  • bazuki54
Posted January 17, 2008 - 07:17 PM
Thanks for the help. I will be putting on a DR.D for sure. I'm coming off a 2005 CRF450.
  • cacimx622
Posted January 17, 2008 - 08:13 PM
Get this system, 2 turns out on the fuel screw and go 50 in the back.This bike rip's.
My lap times are 1 second faster then on my 06 RMZ 450's.:cool:
  • bazuki54
Posted January 18, 2008 - 07:09 AM
I wanted to get a fmf but I have a dr.d sponsorship. does anyone know what bend the protaper bars are? I been using Henry/Reed for four years now and just curious about what's on this bike. thanks.
Posted January 18, 2008 - 07:19 AM
They are lower than the Henry's, I can tell you that.
  • Wes Woodin
Posted January 18, 2008 - 12:54 PM
Welcome to the Blue and White Side!:cool:
  • Wes Woodin
Posted January 18, 2008 - 12:56 PM
Here Ya Go! PM if you are interested!
http://www.thumperta...ty VS powerbowl
  • rickallen124
Posted January 18, 2008 - 01:06 PM
According to protaper the yz-high is the closest bend. I also have been running the henry/reed bend but am thinking about the windham bend as I'm 6' and it doesn't have as much sweep as the henry bend. Might be a little more comfortable.
  • todds924
Posted January 19, 2008 - 09:10 PM
Its a special OEM bend for the 08's. You can only get that bend by ordering the stock part from the dealer.....which sucks because they are ridiculously priced and i like the new bend. After i bent my stock 08 bars i threw on the Henry/Reeds.
  • twenty34
Posted January 19, 2008 - 09:59 PM
can't comment on the race gas, but a Dr.D pipe on a Honda provides marginal improvement compared to a YZ. It's GREAT on a YZ and practically a must have.
On my Honda, all it really did was quiet it down. The Honda has a midrange that is so powerful, the reason for a pipe was to tame it and spread it out the power delivery - you know, kinda like a YZ. :applause:
http://www.thumperta...ad.php?t=582714
  • twenty34
Posted January 19, 2008 - 10:07 PM
Don't tell anyone, but I'm running the stock Pro-Taper bars from my 06 YZ on my CRF now. I like the feel.:cool: :applause:
Not a fan of Renthals...Which all the CRF's seem to run.
  • Family Man
Posted January 19, 2008 - 11:11 PM
I just recently put a white brothers aluminum pro on my 07 yz450 and it majorly uncorked the bike. huge improvement. I highly recomend it.
Motocross
  • Hot  491 replies
  • 0 replies
  • Hot  36 replies
  • 9 replies
