Valve Clearance? Help
3 replies to this topic
  • superior
Posted January 16, 2008 - 08:00 PM
Hello I have a 1983 XL600R and I have the service manual. I have removed teh crankshaft and timing mark hole caps and I have the piston at Top Dead Center. I know that the valves clearances need to be (intake .05mm and .10mm for exhaust.
[COLOR="Red"]When the piston is at Top Dead Center, which valves are the intake valves and which valves are the exhaust valves?[/COLOR]
Thanks
  • Thumpmeister
Posted January 16, 2008 - 08:13 PM
The intake valves are the the rear set that are closer to the back of the bike. The exhaust ones are the ones on the front of the head; right where the headers come out.
  • HawkGT
Posted January 16, 2008 - 08:56 PM
Remember there are two TDC's--a compression stroke TDC and an exhaust stroke TDC. To check/adjust the valves all four of them need to be full closed which means you need to be on the compression stroke TDC. Unless the valves are at 0 clearance, you'll know which TDC you're on because each tappet will have a smidgen of play on the compression TDC. Or, you can just watch the valves as you turn it over and notice the valves open/close. Make sure they're all closed as you reach TDC and you'll know that's the compression TDC.
  • martinfan30
Posted January 17, 2008 - 08:24 AM
The cam lobes should all be pointing downwards at a slight angle. This is compression TDC.
  • Hot  35 replies
  • 22 replies
  • Hot  60 replies
  • 4 replies
  • Hot  186 replies
