Gear Ratios and SPEED !
4 replies to this topic
  • thedktor
Posted January 16, 2008 - 08:13 AM
Hi all
Looking to replace my ex-XR650 with a used WR450.
Looking at gear ratios it seems all years use the same?
Primary reduction ratio 62/22 (2.818)
Secondary reduction ratio 50/14 (3.571)
Gear ratio:
1st 29/12 (2.416)
2nd 26/15 (1.733)
3rd 21/16 (1.312)
4th 21/20 (1.050)
5th 21/25 (0.840)
Now, I want some tarmac performance so will gear it up a tooth to 15-50, which according to my gear calc will still give a lower 1st gear than I was running on a DRZ400 (with 15-47), which was a little high geared off-road but not a problem for me. But on road much better.
DRZ - Primary reduction 2.96
DRZ - Gears
1st 2.285
2nd 1.733
3rd 1.375
4th 1.09
5th 0.863
Has anyone got a WR450 gear calc so I can check my figures? Does anyone run 15-50 for dual-use? I want to cruise at 70mph ideally.....
Thanks
TD
  • thedktor
Posted January 17, 2008 - 07:00 AM
Oh come on Pl-e-e-e-e--e-a-se !
Anyone got a gear calculator ??
TD
  • 123BigcoopDawg576
Posted January 17, 2008 - 08:50 AM
calc no but you can gear this bike no problem....i run 15/48 for baja and dual sporting rides and even some desert and this bike will pull it no problem
  • SXP
Posted January 17, 2008 - 02:10 PM
The primary reduction ratio on the 07 changed. As a result, the standard 13/50 gearing on the 07 is more or less equivalent to the 14/50 on previous year bikes.
  • thedktor
Posted January 18, 2008 - 03:57 AM
OK thanks - useful to know. So an 07 is easy to gear up then eh.
TD
