Started my USD conversion. Need some help...
46 replies to this topic
  • martinfan30
Posted January 21, 2008 - 09:49 AM
#21
What do you estimate total cost start to finish? Looks great BTW...
  • Coolidge
Posted January 21, 2008 - 10:04 AM
#22
I paid 300.00 for the fork set-up, which was already fitted to a XR400. I have a 40.00 upper clamp on its way, so I can run my IMS tank. So total was only appx 350.00-ish. (Thanks for the compliment) I have a 200w stator, CR rear fender, and the Excel wheels to do next.
  • swechilli
Posted January 23, 2008 - 01:30 PM
#23
Hello!! You got a really nice bike:) I doing the same swap now and I would like to know how you resolved the speedo problem? And were do I buy the stickers "showa".. sweet
  • Coolidge
Posted January 23, 2008 - 03:17 PM
#24
Well, I just ordered a ODO eliminator from Enduro Eng. I will either use my Garmin GPS (for awhile) or get a Trailtech vapor digital. I was checking out a CRF250X and the speedo gear drive 'looks' like it may work? Not sure, Im thinking the Vapor will work fine. You can probably get the SHOWA skins/stickers @ TT store, or I know Rocky Mountain ATV/MC has them. Hope to see some pics of your bike!
  • Rockjockey
Posted January 23, 2008 - 05:47 PM
#25
ICO makes a nice speedo/odometer for the dual sport machine as well. It is the ICO VRL. Keeps time, total mileage,resettable trip meter, and is a speedometer just switch back and forth between options with the thumb switch. It is backlit and hooks to your existing battery as well as having an internal battery backup. I put one on my 650L. They make one that does not require an onboard battery too.
  • b2dude
Posted January 24, 2008 - 11:08 AM
#26
I did this swap on an XR400, which should be nearly the same as the 600. I used 1991 CR250 forks. I used the XR wheel and the CR caliper clamp. I kept the XR caliper and it bolted right up. However, I did place a washer between the caliper mount and where it bolts to the fork, just to center the caliper with the rotor better.I had no rotor bolt interference. [COLOR="Red"]I used the XR axle and spacers except for the one that threads onto the end. I used the CR spacer there, because the lip on the XR kept it from resting in the axle clamps.[/COLOR]
FYI, different years have different tube diameters, so not all are interchangeable.
i don't know what the 400 front looks like, but for my 650l this makes no sense. since the cr front clamps the axle on both sides, and the xr clamps on one side and threads into the other, how could the xr axle work?
  • Coolidge
Posted January 24, 2008 - 11:27 AM
#27
Not on the CR frt end I used..... Mine has clamp 1 side, other side is threaded, just like XR axle, except spacing & thread diameter are different CR/XR
  • b2dude
Posted January 24, 2008 - 07:38 PM
#28
ahh yeah i have kyb forks from an 01 cr500 you've got showa. makes sense
  • Coolidge
Posted January 27, 2008 - 06:09 AM
#29
Update, I now have my 4.7gal tank back on :cool: , I fabbed up a couple of brackets (after wasting more $ on another set of clamps :applause: ) that sets tank back just enough to completely clear my 4.7gal tank (appx .5" back) I had to move seat back too, and those large gaps between side panels/tank are tight, and look better. I'd add a couple of update pics but my camera quit after last ride.
  • tp3dxf
Posted January 27, 2008 - 11:36 AM
#30
Cool post bring on the pics. I just picked up a 04 XR600 with a plate to add to the stable.
  • Coolidge
Posted January 27, 2008 - 06:48 PM
#31
...will do. I gotta get a camera together 1st. Mine is done! I am STOKED to get my big tank back on.
  • Coolidge
Posted January 29, 2008 - 08:17 AM
#32
Here you go, pretty much done (for now):
  • fasterfaster
Posted March 04, 2008 - 12:15 AM
#33
Hey Coolidge, nice pictures... your bike looks great! I am going to start a USD swap on one of my XR400'S in a few days. I'm hoping to get the same great handling improvements out of it as you did. I don't expect any problems, I hope. I'll post pictures as soon as I'm done and as soon as I get my engine done and back in. Also see that you have a 1969 GTO in the garage. Very nice. I had a 1968 years ago.
  • Coolidge
Posted March 04, 2008 - 10:17 AM
#34
Thanks. The fork swap was a good swap, very happy with it. Good eye on the GTO, that one is all steel and runs 10.90's.
I also ave a 69 GTO Convertible and a 64 GTO Tri-power :thumbsup:
Good luck w/your swap and be sure to post some pics
~Guy
  • martinfan30
Posted March 04, 2008 - 10:29 AM
#35
:thumbsup:
Looks like she's ready for April!:eek:
  • Coolidge
Posted March 04, 2008 - 10:47 AM
#36
:thumbsup:
Ohhhhhhhhhyeah! I have/had some trouble w/the 200w stator (for my big-azz lights) But have since added gold Excel wheels, w/gold Talon hubs, Talon sprocket, new DID chain. Even got the GPS hardwired, and working. Cant wait for April!! :D
  • kuritaro9
Posted March 04, 2008 - 05:06 PM
#37
nice fork swaps...:thumbsup:
im in the process of doing my XR600 with some modded 2001 cr250 forks and clamps. the forks and wheel are on, and everything is pretty much done except for the speedo set up.
does anyone happen to know if a speedo box drive "at the wheel" from maybe a crf X would work on the cr wheel?
the reason i would like to keep using the stock speedo is, that over here in japan, they record the mileage every 2 years during the inspection process, and i havent found a good way to program my trail tech to match the current mileage 11000km...
thanks in advance for any help...
  • fasterfaster
Posted March 04, 2008 - 05:15 PM
#38
kuritaro9, I just ordered a CRF450X speedo gearbox to go with my CRF450X USD conversion. When it comes in, I will let you know.
  • kuritaro9
Posted March 04, 2008 - 05:18 PM
#39
sweet, thanks man.:thumbsup:
i was planning on just ordering one to see if it would fit, but the current yen/dollar rate is in the toilet, and didnt want to potentially waste the money...
  • Brtp4
Posted March 04, 2008 - 05:57 PM
#40
I am working through this now. The main question is, does a CRF wheel fit your forks? If the answer is yes, then you can get a CRF-X wheel, speedo drive, and cable, and it will hook up to your gauges and work normally.
I am swapping 07 CRF 250 forks onto my L and keeping the stock instruments. I purchased an X wheel and everything bolts up and works well. You need the X wheel because it has slots for the tabs on the speedo drive, and you need the X cable because it is threaded on both ends.
If the axles and spacing are same, it should work.
BP
  • Hot  29 replies
  • 17 replies
  • 22 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  35 replies
