YZ450F Head Gasket Question
1 reply to this topic
  • wflee26
Posted January 15, 2008 - 06:00 PM
Hello again great and wise TT-ers!
After pulling apart my yz450f motor in search of a water leak, I took a closer
look at the head gasket and base gasket.
As you know, the gasket is for a special piston from Wiseco. I noticed that
even though there was no rupture in the gaskets, the passages in the gasket
for the water jacket did not match up to the water jacket of the cylinders,
at all.
Is that normal?
Thanks in advance,
Posted January 15, 2008 - 07:07 PM
It's not unusual for a head gasket to mismatch the passages at the cylinder or head deck. In the automotive world, head gaskets will often be used to adjust and modify circulation in one engine type for various applications.
What you need to be certain of is that there is no point at which a mismatched gasket allows coolant to flow from the cooling jackets to the oil anywhere where the oil lives.
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
Need help by Goforaride
  • Hot  68 replies
  • Hot  131 replies
  • 9 replies
