Magura hydraulic clutch HELP!!!
3 replies to this topic
  • homer450F
Posted January 14, 2008 - 10:29 PM
Hey Guys I been trying to install a Magura jack clutch and I am having a problem with it the slave cylinder hitting the starter mouting bolt.
I have a 2007 WR450F.
I talk to a guy at the local cycle gear and they called Magura and said it would fit. The paper work says it goes from year 05-06. There is no part number for a 2007 WR450F. Should I have gotten the WR250F jack clutch??
Has anyone put the Magura jack clutch on a 2007 WR450F?
Thanks,
Homer
  • clark4131
Posted January 15, 2008 - 06:19 AM
PM Looks450, he mounted one on his '07...SC
  • William1
Posted January 15, 2008 - 06:30 AM
It will fit. The slave cylinders on all the clutch jacks are the same Differences in bore size only).
What part of the jack is hitting the starter?
  • homer450F
Posted January 15, 2008 - 08:21 PM
It is one of the mounting bolts on the starter that has the ground wire on it.
