650R flood during hard braking
4 replies to this topic
  • rhythmofbeing
Posted January 14, 2008 - 09:39 AM
During hard braking (especially stoppies) my 650 will go really rich and often stall out. Has anyone experienced this before? I'm not sure if it's a jetting problem, a fuel delivery problem, or just the way the bike works. I have a Clarke desert tank on it, if that makes a difference.
  • hondacrf150f1
Posted January 14, 2008 - 10:08 AM
ive had the same problem:excuseme:
you explained it a lot better than i could have, ive had the bike stall at stop signs, cause i pulled a stoppie into it, i had the clutch pulled in so there should have been no problem. Not only that but when i just normaly brake and downshift to come to a stop the bike idles really low and sounds like its gona die. I did a airbox mod and havent re-jetted yet so that might be part of my problem. Being new to working on bikes the fricken Carb is 1 hard thing to dial in wonce you **** with it.
  • Maroast
Posted January 14, 2008 - 10:09 AM
check your float height. if the float (in the carb) is too high, when you break hard the front dives, gas in the float bowl shifts and can push the float up and cut off fuel supply. I use to have the same thing happen during hard breaking or riding down steep hills.
you can take the float bowl off and bend the "tangs" on the float so that it sits lower. Kinda hard for me to explain....but does that make any sense?
  • dmvmechanics
Posted January 14, 2008 - 12:09 PM
it sounds like the float plunger is opening when weight shifts forward. thats why bikes will flood if plunger seals is bad and its parked on a hill. check plunger floats, check seals and look at plunger look for scratches and irregularities. i wouldn't recommend bending the "tangs" too much. they are a little tempermental
  • rhythmofbeing
Posted January 15, 2008 - 09:55 AM
Thanks for the suggestions--now I've got an idea of where to look next.
I did tighten the fuel/air screw (or pilot adjustment, or whatever) last night, which leaned out the idle. Now it doesn't stall, but it's too lean.
Honda XR650L 2017
  • 0 reviews
  • Hot  35 replies
  • Hot  28 replies
  • 7 replies
  • Hot  60 replies
