need help w carburator needle shim for 05 xr650l
11 replies to this topic
  • richar_92692
Posted January 13, 2008 - 08:29 PM
i followed up dave's mods for my carb. for the needle they recomend shim (spacer) 0.03'' thick. I pull out my needle from stock carb and it already has spacer on. I'm not sure what is the thickness and also it doesnt mention that carb needle has any spacer originaly instaled. how do I deal with it?
and if I need some, where to get it? live in southern california
will be thanksful for any advise
newbie
  • DBM
Posted January 14, 2008 - 07:57 AM
Go to Radio Shack and get their "small washer kit". Use the smallest washer in the kit that will fit over the needle.
DBM
  • XR650L_Dave
Posted January 14, 2008 - 08:49 AM
If it already has a shim, someone has maybe already done the rest of the mods?
Dave
  • martinfan30
Posted January 14, 2008 - 09:11 AM
slide drilled?
  • richar_92692
Posted January 14, 2008 - 12:30 PM
yes. I performed the steps as on the web page, only the problem I wasn't sure about is the needle shim. I pull out the needle and it had spacer on (dont know how thick is it). This bike came w no mods - I bought it with 120 miles from the guy who didn't even now how to adjust his chain. I would doubt that he chimed carb needle. specially after 2 rides with 120 miles and 2 accidents.
should I just place new shim on the top of existing or what do I do?
  • martinfan30
Posted January 14, 2008 - 12:44 PM
Check this link. It has all the info you'll need...
http://www.4strokes....xr650lcarbmods/
You may need to get an inexpensive Micrometer to measure the shim.
  • XR650L_Dave
Posted January 14, 2008 - 02:20 PM
I would leave as is if it feels good, replace with a known .030-inch shim if it doesn't feel quite right.
Dave
  • TexasXR650L
Posted January 14, 2008 - 04:13 PM
I think mine had a shim in it when I did the dynajet. I kept it
  • richar_92692
Posted January 14, 2008 - 07:01 PM
what do you run for pilot jet w 165?
today I did ad one shim .02 on the top of original one and I had to remove it - didn't run the best in the first 1/4
  • SniperTeamBravo
Posted January 15, 2008 - 09:38 AM
it may be a nylon spacer from the factory. Install another small washer about the same thickness and youll be good. Use both of them....needle position isn't anything but a transition from pilot to main so it isn't that critical in most instances unless the motor is highly prepped for racing.
  • martinfan30
Posted January 15, 2008 - 10:39 AM
That actually defeats the purpose of the djet needle with 5 clip positions.
The shim used in daves mods is used due to the fact the stock needle doesnt have clip positions to change.
  • SniperTeamBravo
Posted January 15, 2008 - 01:58 PM
Correctumundo! AND, The dynajet needle has 5 or 6 clip positions...
