07 wr450 fork seal replacement
2 replies to this topic
  • MaynardF16
Posted January 13, 2008 - 12:46 PM
My WR450 blew a fork seal on the third ride and I need to replace it. I have a small dent (learining curve moving from a 250 to a 450) in the lower tube that may be causing it to leak. I have the forks here but the owners manual is out in the desert with the rest of the bike. Two questions:
1) Does the 07 WR450 shock disaasemble like the one in the FAQ? I rebuilt my 03 WR250 fork using that without any problems.
2) What is the oil height/quantity for the 07?
Tried searching but nothing came up. Thanks in advance.
07 WR450
03 WR250
06 TTR90
  • rich1167
Posted January 13, 2008 - 01:05 PM
can't your answer question. But heres a link to your manual:
  • MaynardF16
Posted January 13, 2008 - 04:55 PM
Thanks for the link. I found what I was looking for. It is too bad they don't let you print the sections you need. To answer my questions:
1) Yes the FAQ section will work.
2) The height is 132mm.
Thanks again
07 WR450
03 WR250
06 TTR90
