Bent Rotors
4 replies to this topic
  • honeycutt
Posted January 11, 2008 - 04:04 PM
Okay, went riding through some rocky Arizona washes and now I have two bent rotors and nasty squeal coming from the front somewhere. I'm hoping it's from the front rotor. Any recommendations for new rotors and disc guards. Thanks!!!!
  • snakesausage
Posted January 11, 2008 - 08:31 PM
I had a bent rotor on the rear of my 05 wr450 and just whacked it with a hammer and a block of wood. It straightened out in the second hit. I do not know how bad yours are but you might give this a try before buying new ones.
If your bike is new enough you may be able to get OEM wave rotors for an 07 YZ450
Also, it is a good idea to list your year and make when asking questions about your bike (or in your profile "my garage").
  • brad the best
Posted January 11, 2008 - 11:51 PM
you could also figure out were it is bent and put it in a vice and bend it back with a big crescent wrench (adjustable wrench) like a 18" or so .
or hit it with a dead blow hammer on some wood , its amazing what you can bend back with a hammer .
  • WR_Dave
Posted January 12, 2008 - 05:21 AM
Disks can be bent back into shape a time or two, except it's never exactly straight again and it causes accelerated pad wear. You can buy disks here for a pretty good price (Tusk).
http://www.rockymoun...CF64D.westring1
I also recommend any kind of rear disk guard or shark fin that isn't plastic. I use a Devol guard but it's been on my last three bikes and I haven't had a reason to do more than bend it away from the rotor a few times. It took the hit, not the rotor. On the front I have seen the metal guards as well , but I have never used one. I have been lucky with the Cycra plastic front disk cover as the plastic lets the rock kind of slide past the rotor while the plastic acts like a bit of a cushion between the rock and the rotor. Maybe I'm just lucky, but I have been riding in the Rocky Mountains for 25 years and their called Rocky for a reason. WR Dave.
  • honeycutt
Posted January 12, 2008 - 07:03 AM
I'll try to straighten them and hopefully that stops that squeal. I forgot to mention that it is on my 07 WR450. Thanks for the help! That Cycra looks nice!
