2003 wr450f clutch question
3 replies to this topic
  • graazzy
Posted January 10, 2008 - 09:14 PM
When i pulled the clutch plates out to look for notches on the clutch basket fingers,i found two spacer rings that are not mentioned in the workshop manual.They were sitting against the inside face of the basket,one is dish shaped with the words "out side" stamped on it ,The other shaped flat.does anyone no about these, can i leave them out?:banghead:
  • brt 426
Posted January 16, 2008 - 01:12 AM
No need to leave them out.
They are called -clutch damper spring and seat plate. You need to recheck your manual or check the 426 manual for there location. In my 426 manual it shows they are fitted first upon reassembly, before any clutch plates are fitted.
Have fun
  • graazzy
Posted January 17, 2008 - 01:07 AM
thank you i did reassemble them as you said,may be the previous owner has fitted a 426 clutch.
  • SJMC_DON
Posted January 17, 2008 - 12:22 PM
Yeah, I don't remeber those on my 04' and I had that clutch apart several times:excuseme:
