What floor to put on a 4x8 folding trailer?
15 replies to this topic
  • AEsco48
Posted January 10, 2008 - 04:00 PM
What type of floor would you guys suggest i put on my 4x8 folding trailer, 95% of the time it will only have 1 bike, max of 2 bikes...
Something that will last a long time and wont rust...wood, Al diamond plate?
Thanks!
  • ORrooster
Posted January 10, 2008 - 04:11 PM
Painted steel grate.
  • usmcpaul
Posted January 10, 2008 - 04:16 PM
If I had unlimited funds I would do the Al diamond plate, however treated wood will last a long time, is easy to bolt things to just in case you want to make changes for different loads.
Al diamond plate is not cheap these days.
  • Chickenhauler
Posted January 10, 2008 - 04:20 PM
The best choice for these folding trailers is 3/4" Treated CDX Plywood. It adds structural rigidity to the frame, helps prevent torsional twisting, and is long lasting.
THe downer of the expanded metal idea is it has approx 0 resistance to flexing (and these little trailers are flexier than a yoga instructor on their own).
The downside of Aluminum plate is when it gets wet, it gets slicker than snot, especially in riding boots, etc.
  • ORrooster
Posted January 10, 2008 - 04:38 PM
That particullarly is why I wouldn't use it. Wood would be my second choice (only 1 opinion).
  • LeadDoggy
Posted January 10, 2008 - 04:43 PM
I used 3/4 plywood on mine, treated with a watersealer. Been holding up nicely for being out in the weather.
  • vetteguy
Posted January 10, 2008 - 05:36 PM
Same here. I don't have my trailer anymore but that is what I did and it worked great. Guy
  • newblood
Posted January 11, 2008 - 02:26 AM
anybody tried using that composite decking material (maintenance free)
  • pfunk
Posted January 11, 2008 - 05:58 AM
+ if you use al plate you have to run stainless everything else or it will corrode fast
  • 2006wr450f
Posted January 11, 2008 - 08:24 AM
On mine I have 3/4 plywood and it works great.
  • Mr-Xtreme
Posted January 11, 2008 - 09:03 AM
Though not the cheapest solution, I decked mine with exterior grade plywood that has been coated with Herculiner. $75 a gallon! That gallon will just barely cover a 4x8 sheet with 1 coat on the bottom, 2 coats on the top, and extra coating on the edges. Perfect non-skid surface. And it will probably last a long time as the plywood is now encapsulated in urethane.
For an aluminum deck there is a new non-skid tread plate available. When my deck wears out this will be its replacement (if the trailer doesn't rust away first!).
http://www.imsmetals...mtreadplate.pdf
It's the same price as the old pattern tread plate. IMS has 4x4 sheets in 3 thicknesses (0.65, 0.10, 0.125), priced at $3.94 per pound if I remember correctly.
  • pfunk
Posted January 11, 2008 - 09:29 AM
wow, thats a lot of money considering the recycle rate is about a buck a pound for high grade. Im sure it can be had for less. I allways order metal by the ton rate. depending on th material, you can expect to save 40-60%. In other words, get a bunch of buddies and head dow to the city and get a ton from the manufacturer. some places will only sell to a business, so have a tax ID number ready, or see if they will charge tax for you. because at 4 bucks a pound, at a light guage your looking at 200+ per sheet. Its been a while since I ordered steel/aluminum (like 2 years) and by the pound aluminum wasnt close to that much, even the price of diamond 1/8 cold forged steel (structural grade) it ended up being 20 bucks a sheet (4x8)
youll see a lot of middle man steel shops that order it from central places and cut it and make a killing
  • Mr-Xtreme
Posted January 11, 2008 - 10:56 AM
You're right that it's probably not the cheapest way of getting metal. I think IMS is the only distributor in my area with that particular non-skid tread plate.
It would cost about $180 to cover a 4x8 trailer with 0.10 thick tread plate which is only about $80 more than what my plywood/Herculiner deck cost. If I were to do it again, I'd pay the 80 bucks.
Also I don't know 45 guys that want to deck their trailers, to get me to the ton rate :banghead:
  • pfunk
Posted January 11, 2008 - 11:06 AM
a lot of times, you really dont have to order one ton, exspecially in aluminum or specialty steel (weird cross sections)
  • PumpkinHumper
Posted January 11, 2008 - 11:07 AM
Yep thats what is on my flat trailer. Been on there for probably 10 years now and still going strong. I hit it with water sealer about 2 years ago just to freshin it up a little. So far so good. It sits out in the rain all the time so that water sealer must be doing its job.
  • damone
Posted January 11, 2008 - 11:52 AM
I have some 3/4" CDX plywood that has been in the rain for 4 years now with virtually no signs of wear. It was given to me and I was told it was near $100 a sheet. I believe it cuz I got a 7/8" sheet of regular plywood to fill around my windows and it was $60 a sheet.
the remainder of that sheet has gone a long way to making leveling boards for my ToyHauler.
