new clarke 3.3 gallon tank questions
6 replies to this topic
  • 2001YZF426Rider
Posted January 08, 2008 - 07:45 PM
I just put a 3.3 gallon clarke tank on my 426.. My question is, if i get another petcock, from which year do i want? And, how do i connect the two fuel lines coming from the petcock, to go into one, with a "T" connection?? Anybody have pics of their setup?
Posted January 08, 2008 - 10:31 PM
I used an '03-'05 YZ450 petcock on the right side and went forward with the fuel line up over the header and behind the radiator.
Then I modified another '03 petcock on the left to eliminate the T fitting:
http://www.thumperta...398#post5491398
On the Clarke tank, the right side petcock sits too close to the head to use an '06 valve, which would run the line rearward, because that valve offsets inward a little and would hit the head.
  • 2001YZF426Rider
Posted January 09, 2008 - 09:04 AM
Did you have a problem with the first setup you had??
I dont need anything fancy, just something that works.
Posted January 09, 2008 - 10:20 AM
That would be this setup, with the plastic Y in it:
No problem, but it wasn't clean enough for me, and I was concerned about the Y turning brittle.
  • 2001YZF426Rider
Posted January 09, 2008 - 11:03 AM
Ok.. How long did you have that setup like that?? i wonder if i can find a y out of brass or something instead of plastic..
Posted January 09, 2008 - 12:16 PM
I looked all over, and the only Y that compact was plastic. I didn't look everywhere, though, so rage on if you like. I only have so much time to hunt for stuff. One alternative was to make one from copper tubing, but the way I did it was probably less work. The plastic Y was there for 7-8 months, and is mad to be under an automobile hood, so the risk of it becoming brittle is probably pretty low.
  • 2001YZF426Rider
Posted January 09, 2008 - 12:47 PM
i will try that!! Thanks a lot for the help!!
One other thing, is there an easy way to get this damn tank on? Mine is a pain to get on right where the front of the tank mounts to the frame, those rubber pieces hit where the bolts go through, i have to take off one side mount and get the other side lined up then put the other one on, its a major pain!!
  • Hot  47 replies
  • Hot  50 replies
  • Hot  38 replies
  • 10 replies
