Will XR650R whlles fit an XR600R?
5 replies to this topic
  • SniperTeamBravo
Posted January 08, 2008 - 09:10 AM
2002 XR650R, will the wheels off of it fit directly on a 1996 XR600R?
Thanks.
  • mikey 4410
Posted January 08, 2008 - 12:19 PM
no they dont.i know that much
  • SniperTeamBravo
Posted January 08, 2008 - 12:22 PM
Have you tried or are you guessing? Because from what I have been told on another site is they do.
I figgured I'd ask someone who has tried it here.
  • kidcurry600r
Posted January 08, 2008 - 12:28 PM
I noticed when I looked at my bro-in-laws 2000 650r next to my 1995 600r, that the brake rotor is a lot smaller on the 600r. So even if it would fit a rotor swap would be needed.
  • SniperTeamBravo
Posted January 08, 2008 - 12:39 PM
He would use the stock rotor, but are you sure he didn't have an aftermarket rotor on the 650? I looked at a ton of pics and the rotors look exactly the same diameter on both....
  • michaelxr
Posted January 08, 2008 - 08:41 PM
I've been researching wheel swaps the past two weeks. I'm surprised there isn't more information. There really needs to be a Honda XR wheel swap table out there. :banghead: I've been trying to find out if XR650L wheels will fit my XR400R.
From what I've found, 650L, 650R, 1993 and newer 600R, and 400R front wheels bolt right up, they're all compatible.
Rear wheels are somewhat different. The 650R has a 20mm axle, 20mm inside diameter bearings and dust seals. Not sure if you can change those parts out with 17mm OEM parts for the 600R or not. I've found that an
XR650R rear wheel can interchange with an XR400R rear wheel by changing out the bearings, seals, and spacers for the 400R.
I'm trying to buy a second set of wheels for street/supermoto and trying to buy used. So I'm looking at any 17" supermoto wheels for XR's and trying to figure out if they will fit my 400 or not.
Good luck.
