JB Weld AIS?
5 replies to this topic
  • atitagain
Posted January 08, 2008 - 07:04 AM
Has anyone JB Welded the openings from the air cut-off valve? Would there be any harm done in disabling it in that manner? It looks like they are doing that in the CRFX forum.
  • erickdj
Posted January 08, 2008 - 07:12 AM
I did that on my WR. No harm done, it has the same effect as removing the AIS pump. All you're doing is preventing the flow of exhaust gases. I did it like that to avoid issues with the rangers at the riding areas, nobody has looked at my bike trying to find the AIS, but just in case they do.
  • KennyMc
Posted January 08, 2008 - 07:36 AM
Yea, mine is off but I have kept it just in case. As soon as I hear of any local enforcement, it will go back on in the same shape that I took it off:busted:
  • atitagain
Posted January 10, 2008 - 01:26 PM
I bought some JB weld and I took the pump off...then I was thinking... wouldn't just taking out the metal reed and cutting out or removing the diaphram disable the pump:excuseme: ? Has anyone tried this?
  • old man dan
Posted January 10, 2008 - 01:28 PM
I just put a ball bearing in the rubber line to disable it. Easy to undo if you have to and looks perfectly stock.
  • William1
Posted January 10, 2008 - 01:59 PM
Plugging up the little vacuum line will disable it. Keep in mind, the port in the head will eventually carbon up and if you try to re-enable the AIS it will not work. The kits like the one from F2, have a plug that is inserted under the Allen bolt plug on the head and will prevent the port from clogging. You can then leave everything on, and do the ball bearing trick. I just pulled everything off, no one on the east coast looks for that stuff.
