yz426 could i have messed something up
4 replies to this topic
  • 29-keith-29
Posted January 07, 2008 - 10:32 PM
i just put a new crank in my 01 yz 426 and after geting it all back together i started it up and its leaking oil from the side case of the stator reaky bad and on the other side not the clutch cover but the side case i used all new gaskets and tightend evrything and its still leaking what could be cousing this??:banghead: please help
Posted January 07, 2008 - 10:45 PM
You need to identify the exact point where the oil is coming from, as in from between the stator cover and the crankcase, or from between the oil feed line ant the right engine cover.
  • 29-keith-29
Posted January 07, 2008 - 10:50 PM
between the stator cover and the crank case all along the bottom there. and on the throttle side right under the oil feed line but not the oil feed line it seems to drip from the motor and onto the frame and its leaking prity bad
Posted January 08, 2008 - 06:12 AM
The 4 most likely reasons that gaskets fail to seal are:
> The old gasket was not completely removed, or
> The cover (or whatever) was over tightened and the gasket has split around one of the bolt holes.
> The gasket is out of position.
> An inappropriate sealer was used (Silicon RTV causes more leaks than it fixes when used on gaskets like this.
Also, if either of the mating surfaces or the gasket were damaged during installation (gouged, cracked, cut) that could do it.
  • 29-keith-29
Posted January 08, 2008 - 01:00 PM
i probly over tightend it cuz the gasket ripped around acouple of the holes now i have to do the other side witch is going to be a pain
  • Hot  50 replies
  • 3 replies
  • On January 15, 2017
  • 0 replies
  • Hot  28 replies
