radiator fluid question
10 replies to this topic
  • nap__kxf
Posted January 04, 2008 - 06:50 PM
i put a set of those new blue radiator hoses on my bike (they look so badass) and like an idiot just about all of my radiator fluid spilled on the ground. that catch bucket didn't really catch anything.
but the oem fluid is in there and i went out and bought some coolanol and i read here on thumpertalk that you don't mix the orange fluid with the green stuff, but the oem fluid and this coolanal are both green.
so would it be ok to mix those two? or should i completely drain the oem fluid?
  • MX1967
Posted January 04, 2008 - 07:15 PM
Drain it all out & replace with new coolant. My 06 gets new coolant every year along with fresh brake fluid.
  • nap__kxf
Posted January 04, 2008 - 07:16 PM
i have an 07 which is basically the 06 so how do you completely drain it out? take off the water impeller cover or what?
Posted January 04, 2008 - 08:12 PM
As they say, "RTFM".
Removing the lower water pump cover bolt (the one with the copper washer) while the radiator cap is off drains the entire cooling system. Pour a quart or so of water through the system to rinse it.
Don't depend on color to tell you anything, read the label. The issue is that ethylene glycol coolants and propylene glycol coolants should not be mixed.
  • SXP
Posted January 04, 2008 - 08:19 PM
As they say, "RTFM"
Now, now, Gray! Be nice:shocked:
:banghead:
Posted January 04, 2008 - 08:26 PM
If I was trying to be harsh, I would have left it at that, and not provided the info, no? :banghead:
  • SXP
Posted January 04, 2008 - 08:30 PM
Actually, I was being facetious. Hence the :busted: I think you are way too tolerant/helpful of the questions asked here when people SHOULD be RTFM.
Posted January 04, 2008 - 08:32 PM
I spotted that right away :banghead:
  • nap__kxf
Posted January 04, 2008 - 10:34 PM
sorry i didn't think the manual would tell me whether or not it'd be ok to mix the different brands of coolant.
Posted January 04, 2008 - 11:24 PM
Top of page 3-7, and in better English on the coolant label. The manual does also explain the draining procedure, too. :banghead:
  • nap__kxf
Posted January 06, 2008 - 06:03 PM
Top of page 3-7, and in better English on the coolant label. The manual does also explain the draining procedure, too. :busted:
oh wow. i'm an idiot. theres a drain bolt, my god.
i need to keep this fangled manual out in the open so i can use it more often.
:banghead:
  • 10 replies
  • Hot  36 replies
  • 5 replies
  • Hot  28 replies
  • Hot  30 replies
