Reed's '08 YZ450F
44 replies to this topic
  • 5valve
Posted January 05, 2008 - 04:35 AM
#21
That rotor is made by Braking and is called the Bat Wing Rotor. I wanted to buy one until I found out it was $600.00! No kidding! I could get cost on it and it still would have cost me $450.00:worthy: All hail the factory teams!
much cheaper overseas, 250$
  • Ga426owner
Posted January 05, 2008 - 06:30 AM
#22
Tivo it up boys Mudfest #1.....what with 3 -10inches expected.....it is going to be a mess:naughty:
  • rickallen124
Posted January 05, 2008 - 07:03 AM
#23
It looks like Gibbs racing is running some different motor mount brackets. I wonder if they fabricated those themselves. Probably as I'm sure they have a in house machinist that could make anything. It would be interesting to know if they found some handling improvements by changing the flex of the motor mounts or if it's just for the trick factor.
  • racer 813
Posted January 05, 2008 - 08:51 AM
#24
All those trick parts and do I see a junk stock chain? (Reeds bike) Some-one tell me I'm trippin!
  • yzfmerf
Posted January 05, 2008 - 09:35 AM
#25
i guarantee that is not a stock chain!
Posted January 05, 2008 - 10:18 AM
#26
The pro teams run high grade, non-sealed chains. They also discard them after nearly every race day at least. Nothing like having a fat budget, eh?
  • swatdoc
Posted January 05, 2008 - 12:46 PM
#27
also - did everyone notice the OIL COOLER on Chad's bike. apparently Yamaha doesn't think they're such a worthless, waste of time!
  • Ga426owner
Posted January 05, 2008 - 01:08 PM
#28
I guess not since GLs bike has one also. They are built into the lower radiator and supposedly the other radiator is from a WR:thumbsup:
Notice also that they are Wetsump motors also with trick ProCircuit oil pumps
  • bosshogg
Posted January 05, 2008 - 01:40 PM
#29
That is EXACTLY what I was thinking. It sure looks like the stock POS to me.
Posted January 05, 2008 - 01:46 PM
#30
That's why they have the coolers. The bike probably only has a total of 6-700cc of oil on board for the combined engine and trans. That's also the reason there is no external pressure balance hose on Grant's bike as noted ealier; with a wey sump, it isn't needed.
On the old bikes, there was an arguable reason for this, because it moved the weight of the oil supply to a much lower point. What the significant advantage is supposed to be over the tank-in-engine layout of the '06+, I have no idea, particularly when you then need to add back an oil cooler to the system you lightened by removing the return pump. If less oil was what they wanted, with a dry sump, they could have just run less, it seems to me.
  • swatdoc
Posted January 05, 2008 - 04:39 PM
#31
Gray - how do you think they're doing the wet sump on the 450's? I would think it'd be a lot easier on the 250's with an external oil tank that could be eliminated; but the 450's as we all know are all internal to begin with???
Ga - I called Pro Circuit and they said they will NOT be making those oil pumps available to the public :banghead:
Posted January 06, 2008 - 12:03 AM
#32
The same thing exactly needs to be done in either case. The return pump is removed and plate separating the two oil pumps is replaced with one that allows the feed pump to pick up oil from the sump screen. The thing that is easier on the old bikes is that the passages that lead from the original feed source and to the original return passage have to be blocked off. That's easy on the old setup, because all you need is what amounts to a pair of oil line end fittings with the lines cut off and plugged. They bolt on the outside.
The new return passage wouldn't be too hard. Just pull the ignition cover and push a ball into the return passage. The original feed passage is another matter. You have to split the cases to get at it.
  • SUnruh
Posted January 06, 2008 - 11:10 AM
#33
i'm pretty sure those cases were split a LOOOONG time ago and all mods done at that point :banghead:
  • honda597
Posted January 07, 2008 - 01:12 AM
#34
I have a question about the AKRAPOVIC exhaust. Are they available to the general public or something similar .
Looks trick as.
  • rickallen124
Posted January 07, 2008 - 06:56 AM
#35
Yes akrapovic pipes are available to the general public through parts unlimited I believe. Now as far as the factory pipe who knows as they get their own spec pipes sometimes.
Posted January 07, 2008 - 08:17 AM
#36
I'm sure you're right. The question was about how the mod would be possible, and the relative ease compared to the external tanked models.
It later occurred to me that one can actually block the original feed passage at the joint of the oil pump to the crankcase from the outside (under the primary side cover) without splitting the cases.
  • ECEAracer
Posted January 07, 2008 - 08:29 AM
#37
Are those Mag Ignition Covers available to the public or is that one of those one off Factory Yamaha kind of things?
  • KJ790
Posted January 07, 2008 - 06:19 PM
#38
I don't think Reed and Langston were running oil coolers. Notice that there are no oil lines coming out of the bottom of the radiator on Reed's bike, and the oil filter cover is stok on both Reed and Langston's bikes (I checked pics from this weekend on other sites). It looks like the 250Fs were the only ones running oil coolers.
  • twenty34
Posted January 07, 2008 - 07:48 PM
#39
Looks trick as.
Interesting when you look at all the bikes - Blue, Green, Red, Yellow and Orange and all the different aftermarket pipes that are used. Even more interesting how popular Dr.D pipes are here with TT riders on this forum, yet you never see one used by a pro? Man, those YZ's looks pretty trick!
Don't kill me, I ride with Dr. D's - Both Red and Blue.
Sorry, I notice the weirdest things as a general rule.:banghead:
Posted January 07, 2008 - 09:07 PM
#40
...I notice the weirdest things as a general rule.:banghead:
'Supposed to be a mark of intelligence, they tell me.
  • On January 15, 2017
  • Hot  36 replies
  • Hot  47 replies
