How to clean cylinder head surface.
1 reply to this topic
  • kubamtx
Posted January 04, 2008 - 04:00 AM
Hello
How to remove the rest of cylinder head gasket from cylinder head? Can I use steel wool ?
  • mxracer206
Posted January 04, 2008 - 04:37 AM
Steel wool or scotch brite would be ok, remember a little discoloration is not a problem as long as the surface is smooth. Be careful with the head/cylinder surfaces as it takes very little to cause a problem. These gaskets are good about not leaving a lot of material on the surfaces when removed.
  • Hot  47 replies
  • 0 replies
  • Hot  113 replies
  • Hot  36 replies
