WR4 gearbox failure?!
3 replies to this topic
  • XR6's_rule
Posted April 07, 2002 - 12:03 AM
I recently bought my '99 WR400 three weeks ago. I was out riding the other day when it started "slipping" in top gear! (damn) I have replaced the clutch without the problem being rectified. So now I'm thinking fifth gear or selector failure, any help much appreciated!!
  • Rich_in_Orlando
Posted April 07, 2002 - 09:04 PM
Same thing happened to my '99 about 3 months ago. I had to replace the shift fork #2 (it was bent slightly, which was the cause of all the problems) and the 3rd and 5th pinion gears.
The dogs on the 3rd pinion gear (#6 in the drawing) had formed little "ramps" which allowed them to slip out of the slots on the 5th pinion gear (#3). It cost me about $150 in parts (2 gears-$76, 1 shift fork-$40 , 2 seals- $10 and 2 gaskets- $36).
  • Taffy
Posted April 07, 2002 - 11:36 AM
yep i had the same problem. the new selector forks will be "beefed up".
while you're there check the kickstart return stop. if this is too badly warn you can't repair it. i was lucky i bought a new stop plate.
Taffy
  • XR6's_rule
Posted April 07, 2002 - 06:48 PM
Thanx a million for your help guys!! Is the selector/fifth gear problem reasonably common to WR4's? There seems to be talk of it here and there.
