Front fork alignment?
2 replies to this topic
  • SteveON
Posted December 30, 2007 - 07:16 PM
I finally got my NX650 back on the road. Yesterday I noticed the upper and lower fork clamps are way out of alignment causing the front wheel to point slightly to the right. Doesn't seem to effect the handling of the bike but I'd like to get it back straight. I've never had to mess with that part of a bike before. I'm guessing all I have to do is loosen up the bolts on both the top and bottom fork clamps and simply allign the two so the front wheel is straight? Anything else I should be aware of?
Thanks,
SteveON
  • martinfan30
Posted December 30, 2007 - 07:40 PM
Thanks,
SteveON
no pretty simple job, just dont let the tubes slip up or down in the clamps.
  • Krannie McKranface
Posted December 30, 2007 - 08:12 PM
Actually, there is a procedure for 'setting' a front wheel in the forks and clamps, so they sit staight, and the disc doesn't rub:
1. get the fork tubes exactly the same height in the top clamps (this is very important to saftey, and the life of the forks). Tighten.
2. Loosen the axle nut side of the fork, the part that clamps the axle (not the axel nut). Tighten the Axle nut once this has been done.
3. Get on the bike and pump the forks up and down with the front brake on. Do it aggressively.
4. Tighten the axle clamps back up.
