Throttle stop mod--Cut VS. remove
6 replies to this topic
  • DDZMCC
Posted October 10, 2002 - 11:18 AM
I want to make the throttle stop mod to my '99 WR400. The instructions from Off-Road.com say shave 8cm off. Why can you not just remove the stop entirely? I have removed the stop and twisted the throttle to wide open repeatedly with it returning to fully closed every time. Is there a risk of the throttle sticking open?
  • levy1
Posted October 10, 2002 - 02:14 PM
I cut mine down to the threads and the bike would not take the last 1/4 turn of the throttle. After reading many posts I have ordered and just received a yz stop which has about 3/8 post after the threads. I will insall this weekend.
  • MN_Kevin
Posted October 10, 2002 - 06:37 PM
there have been issues w/ cracking slide valves. I (believe) the culprit was possibly removing the throttle stop. Wacking the throttle open causes the slide to take the impact, NOT the throttle linkage.
cut off 8 milimeters, not 8 centimeters.
  • x2smoker
Posted October 11, 2002 - 07:13 AM
When I was reviewing bikes prior to purchasing the WR, I remember reading that Yamaha Corp trimmed the stop 7mm (not 8) prior to supplying WR426's for test comparisons. Has anybody measured the length of both the WR and the YZF versions to see what the differencr actually is?
  • MOmilkman
Posted October 11, 2002 - 08:14 AM
Kevin is right.
If you want some more info about it, I posted it on my website.
WR/YZ Tech Info
Hope it helps you.
  • BrandonW
Posted October 11, 2002 - 09:03 AM
hey Darin,
Just got done browsing your web page. Looks good. You got a lot of nice tips there, with detailed instructions.
Nice job!
Brandon
  • MOmilkman
Posted October 11, 2002 - 06:50 PM
Thanks Brandon. I was slow at work one week so I tried to put that week to good use! :)
Some of it came from the old TT Tech site from years ago. I still have a link to it but I wanted some of that info to still be avialable if they ever took it down.
