radiator braces/guards???
45 replies to this topic
  • black_n_blue_thumper
Posted January 09, 2008 - 10:50 PM
#41
Just get Unabiker (the ones that WC stole their design from) and put em on. No trimming, no draining, just bolt em up and go crash. :banghead:
  • rideawn
Posted January 10, 2008 - 11:16 AM
#42
How much material are you removing? was only a tiny little snip of plastic, sounds awfully extreme. :banghead:
Removing nearly all the inside rib from the shroud, and also a 1.5" V from the bottom edge of the shroud. I would've preferred not to have to do that, but it doesn't really bother me. If I could do it again, though, I'd get WC or Unabiker (apparently). The downfall is, if I ever change plastics, I've go to do the cutting again.
  • hi everybody
Posted January 10, 2008 - 04:25 PM
#43
my left radiator's innermost core is squished...like the vertical cores are almost touching, is it too late to get the works connection cages? like will they still fit...even though they're a bit squished? I bent em back straight, so the alignment isn't off too much...
  • youngr24
Posted January 10, 2008 - 08:17 PM
#44
go unabiker, and have no more worries
  • Colorado Kid
Posted January 17, 2008 - 07:15 PM
#45
it looks to me that there may be a problem with air flow through the radiators. alot of the surface area is covered. Have you had problems overheating?
  • DeeCee
Posted January 18, 2008 - 06:43 AM
#46
Fitted Flatland Guards to my YZ400f, didn't need to trim any plastic. Lots of space in behind the guards which also act as a good brace as well.
+1 for Flatland :cool:
  • Hot  38 replies
  • Hot  113 replies
  • 10 replies
