Help revive YZ400...
7 replies to this topic
  • blbills
Posted December 28, 2007 - 11:26 PM
Hello all,
I have been away from riding for the past 6 months and I need some assistance. I took my YZ400 for a spin for the first time in a while and I noticed a sivere bog when I am agressive on the throttle that wasn't there before. I'm planning on going on a huge ride on monday, so I really only have saturday to address this problem and I would love some suggestions as to how to go about it.
I imagine a full carb rebuild is in order due to the gas sitting in the carb that long. I was wondering if there was a quick fix that you may suggest. The bog may also be due to the cold weather. I usually ride in the summer when the temp is much warmer. Could that be causing the bog?
Anyway any suggestions would be greatly appreciated.
Thanks,
Brian
  • SRT426
Posted December 29, 2007 - 02:27 AM
Clean out the carb, clean out the air filter and throw in some fresh gas. Rejet for current conditions since you may be a little lean with your summer jetting. Also don't forget to change the oil since the bike has been sitting. Hope that gets ya going.
  • blbills
Posted December 29, 2007 - 05:30 AM
Hey thank for the tips. I'm not too familiar with the re-jetting. You say that I may need to richen it up. Which jet would that be and how big of a change do you think is in order?
Thanks
  • Qwik Gixxer
Posted December 29, 2007 - 08:00 AM
Budget trick.
Try and run a little injector cleaner through your carb. Put a little in the tank with a full tank of gas. Sometimes it will clean any buildup/varnish out of the carbs. Made a difference on my Bike.
  • blbills
Posted December 30, 2007 - 10:41 AM
Well I did a complete carb rebuild with no luck. It still bogs like crazy. I was hoping that cleaning the acc pump real well would do the trick, but I didn't notice any change. I did notice that the main jet is a 170 (stock is a 175) that may be too lean for the winter time. I know nothing about proper jetting. Would buying a new main jet around a 175 fix this bog? Also what about the pilot screw? Would adjusting this have any effect on the bog. I also made a big oppse while taking the carb apart, I disconnected the tps sensor from the body of the carb. I put it back as close as possible to its original location; so I'm not sure if this is contributing to my problem aswell.
Any help would be greatly appreciated,
Brian
  • BergArabia
Posted December 30, 2007 - 11:00 AM
Budget trick.
Ha that is what I do.. lol..
I keep the carb and injector cleaner handy and pop some in from time to time so I won't have to open the carb. Really don't want to do that as I have 2 left thumbs.. Wish I could help you blbills...
  • blbills
Posted December 31, 2007 - 06:53 PM
Hey all, I solved the bog problem!!! I broke down and bought a JD power kit for the carb and it completely fixed the problem. My bike has never run better! I just wish that I would have done this 3 years ago. Thanks for all your help.
Brian
  • bigbluerider4life
Posted January 01, 2008 - 03:27 PM
Brian
good choice, well worth it IMO :banghead: jetting can and will make a huge difference
  • 10 replies
  • Hot  30 replies
  • 5 replies
  • Hot  50 replies
  • On January 15, 2017
