650R Clutch install/break in?
5 replies to this topic
  • Thumpmeister
Posted December 25, 2007 - 09:24 PM
The clutch on my piggy is getting tired, and I got a new set of plates and springs for an xmas present...
I was reading on the box that you need to soak the plates in oil a few hours before you intend to install them. Thats fine. The only thing is, is I have been running Mobil 1 synth and would like to continue running Mobil 1 synth. However, when I installed my cam, it said that I had to use conventional oil for the break in.
Question is, is do I HAVE to use the conventional oil for the break-in of the clutch?
  • weskc35k
Posted December 25, 2007 - 09:59 PM
Wouldn't think so,just soak 'em and go.
  • XR4DEZ
Posted December 25, 2007 - 10:04 PM
No break in on the clutch. Honda synthetic is compatible with their dino oils for easy change over after engine break in.http://www.rockymoun...dFamilyId=19917
  • Denn10
Posted December 26, 2007 - 11:36 AM
I would use Mobil if i was to replace clutch and i use mobil oil already. Think your fine like said
  • martinfan30
Posted December 27, 2007 - 01:24 PM
all good.
  • TDC71
Posted December 27, 2007 - 02:29 PM
+1 :banghead:
  • 22 replies
  • 3 replies
  • 17 replies
  • Hot  60 replies
  • Hot  35 replies
