2003 450 interchangable with 2005 450???
3 replies to this topic
  • holker1
Posted December 25, 2007 - 06:52 PM
Was wondering if a 2003 yz 450f motor would fit in a 2005 yz 450f?
  • ONLY4STROKES
Posted December 25, 2007 - 07:27 PM
Yes it will, all the mounts are the same.
  • holker1
Posted December 25, 2007 - 07:35 PM
Thats all i needed to know thanks!!!
Posted December 26, 2007 - 12:29 AM
Those two engines are externally identical, and 100% drop-in interchangeable. The ignition mapping on the '05 is milder, and the '05 has a slightly better head. The '05 also has a higher primary gear ratio. The difference is exactly what you'd get if you went up a tooth at the front, or dropped 3 at the rear.
Motocross
  • Hot  491 replies
  • 0 replies
  • 5 replies
  • Hot  36 replies
