15 tooth front sprocket ?
11 replies to this topic
  • ThumperKid250F
Posted December 23, 2007 - 07:20 PM
hey guys well i already started ice racing this year and im needing more topspeed. im already hitting 5th gear wide open just as i come out of the corner so i already have this sprocket for the front but im just wondering can i fit a 15 tooth front..
thanks guys
BTW im running stock gearing right now. ( stock gearing worked great last year but this year we have one big track) :banghead:
Posted December 23, 2007 - 07:29 PM
Assuming you are talking about your '06 YZ450, the stock gearing is 13/49. Yes you can fit a 14 or 15 front. The 14 will fit without modification. The 15 will require you to use the chain guide (case saver) from an '03-'05, or modify yours to clear it.
  • ThumperKid250F
Posted December 23, 2007 - 07:38 PM
ok thanks a lot garyracer and yes im talking about the 06 yz450 :banghead:
  • bluedawg
Posted December 24, 2007 - 06:56 AM
hey guys well i already started ice racing this year and im needing more topspeed. im already hitting 5th gear widopen j i come out of the corner so i already have this sprocket for the front but im just wondering can i fit a 15 tooth front
wow.....its hard to imagine maxing 5th gear maxed out on a 450:eek: must be a lot of lost traction and spinning the rear tire:busted:
  • BergArabia
Posted December 24, 2007 - 08:15 AM
Or just a long flat straight.
Happens to me on my 05 in the desert.. but then I only have 4 gears :banghead:
  • ThumperKid250F
Posted December 24, 2007 - 08:28 AM
no trust me im not loosing traction. its called im on a huge lets say flattrack but its on the ice.
  • Murmy26x
Posted December 24, 2007 - 01:00 PM
If you're running on a 3/8 to a 1/2 mile track a 15/49 might be a tad tall. I tend to run 14/46 on my 07 450's on 1/2 mile dirttracks. 15 fits but I had to take a dremel to the stock casesaver real quick to get clearance but it's maybe a 10 minute job.
Posted December 24, 2007 - 01:03 PM
I think he asked about a 15 because he assumed he had a 14 now. But you do understand that 15/49 and 14/46 are virtually the same ratio, right?
  • ThumperKid250F
Posted December 24, 2007 - 02:27 PM
i dont have a 14 i just have a stock 13 on the front.
but i do have the 15 so im going to try that out and see how it works
thanks guys
  • Boltos
Posted December 26, 2007 - 04:56 AM
What sort of modification is required or is it just easier and quicker to obtain the '03-'05 chain guide? I will be running an '07 YZ450F at Daytona Motor Speedway in a Supermono class in early March 08, and need to gear this bike very tall for that track. I am considering 15/40 (2.67).
Posted December 26, 2007 - 06:26 AM
It's usually as simple as slotting the upper hole the guide so it can be rotated forward a little.
I haven't tried it myself, but I understand that a 16 will fit the bike, but that it requires a notch be cut into the front of the chain slider on the swing arm. Might ask in the Super Moto forum.
  • Murmy26x
Posted December 26, 2007 - 01:04 PM
Yes I do. But I find it hard to believe they're running on a true 1/2 mile therefore making true 1/2 mile gearing a tad tal;l as a 15/49 or a 14/46 ratio is what i tend to run at alot of the pro dirttrack 1/2 miles. Alot of ice riding is done here in Michigan and our tracks are genually more of a 3/8 mile and not a true half mile.
Just from experience thought a 15/49 might be a tad tall and think a 14/49 might be closer. But then again that's gearing for top gear and not taking into consideration running 4th.
  • Hot  38 replies
  • Hot  30 replies
  • Hot  28 replies
  • 0 replies
  • Hot  113 replies
