k&n
16 replies to this topic
  • stevilkanevil
Posted December 23, 2007 - 10:13 AM
do i need to jet if i install a k&N AIR FILTER
  • Krannie McKranface
Posted December 23, 2007 - 10:31 AM
I personally have had bad results with the K&N: I got fine dust in my intake boot, no matter how I serviced the filter. It also has a less suface area than the Foam filters.
I went to a UNI.
  • martinfan30
Posted December 23, 2007 - 11:02 AM
if thats all you do, no. with free flowing exhaust, yes. i also dont recomend K&N. they let too much fine particulate through IMHO. i like UNI foam 2 stage filters.
  • tgstoken
Posted December 23, 2007 - 11:42 AM
I had a K&N on my 650L and I agree, there was fine dust in the engine side of the intake boot. I just switched to a Twin Air foam filter and it seems more protective.
  • PMAZ7
Posted December 23, 2007 - 12:33 PM
I'm just not a "fan" of the way the UNI fits into the airbox.
  • martinfan30
Posted December 23, 2007 - 01:13 PM
on the L, it fits ok. you just have to use the sealing grease around the base.
i know one thing, even with the fit of the k&n being a little better, the uni still filters betters and still flows well. no dirt on the inside surface of the intake.
  • tgstoken
Posted December 23, 2007 - 01:23 PM
The Twin Air filter I have seals better than the K&N and it has a 2 stage foam element like the UNI. I'll try to get a pic up.
  • martinfan30
Posted December 23, 2007 - 01:24 PM
you ride L or R?
  • tgstoken
Posted December 23, 2007 - 01:44 PM
Here's a pic of the Twin Air filter in my 650L. The filter is 2 stage, has a rigid plastic skeleton inside and has a very tight fit to the airbox, no grease needed. And no, my bike NEVER gets cleaned. :banghead:
  • martinfan30
Posted December 23, 2007 - 03:15 PM
i thought this is what an airbox is supposed to look like!
  • tgstoken
Posted December 23, 2007 - 04:32 PM
Sorry Martinfan, the pod filter you use is not really the best choice up here in the wet northwest washington area. If you drop your bike in the mud/water, the airbox affords some protection.
  • martinfan30
Posted December 23, 2007 - 04:36 PM
ya i hear ya. im actually thinking of putting the airbox back together and putting the battery under the seat. a crf450x battery is smaller and will crank a 650 over with a hi comp piston no prob.
  • Denn10
Posted December 23, 2007 - 11:23 PM
UNI or Twin air there both good and you can use grease on sealing surface its just a little more help to make sure you dont have something get through, its does no harm at all only a little insurance.
  • weskc35k
Posted December 24, 2007 - 02:01 AM
Don't do it man.
Step away from the K&N.
  • Frank ZX
Posted December 24, 2007 - 07:03 AM
With all due respect,Your not going to like dirt getting in your engine either.I was going to put one on my XRL,but everyone talked me out of it.I had a K&N on my Mustang,and fine dust passes right thru.
The Uni and Twin Air filters are much better filters for a bike.
Just my and others $0.02
  • stevilkanevil
Posted December 24, 2007 - 02:08 PM
although i do some dirt, most of my ridding is back and forth to work on pavement. Im new to this whole thing and appreciate all the advice.
  • martinfan30
Posted December 25, 2007 - 08:19 AM
i wouldnt use one if even just a little riding is done on dirt.
  • 22 replies
  • Hot  29 replies
  • Hot  186 replies
  • 9 replies
