Putting the pig on a diet
34 replies to this topic
  • jk9270
Posted December 17, 2007 - 11:07 AM
What are the best ways to take a few pounds off an R? I've changed the exaust and lost the kickstand, but after that I'm kind of stuck. Any Ideas?
  • Denn10
Posted December 17, 2007 - 11:09 AM
how much do you weigh??
  • HawkGT
Posted December 17, 2007 - 11:16 AM
Handlebars?
Wheels?
Rear sprocket?
Loose the odometer and cable?
Ti bolts?
Loosing weight off most dirtbikes ain't easy.
  • jk9270
Posted December 17, 2007 - 03:02 PM
Well I'm a bit less than the bike:ride:
I'm about 180, pretty fit and don't think I can lose more than 5-7 lbs myself.
I've already got a pro taper bar also that I forgot to mention. I'm looking into the Emig racing triple clamp to fit some crf forks that I won on Ebay, but I don't know if that will cut or add weight. I plan to lose the odometer and cable when I do that.
I hope to shave 10-15 lbs off the beast to make it more managable in tight woods trails.
I guess we'll see what happens.
  • BWB63
Posted December 17, 2007 - 03:17 PM
you lost 3 full pounds or more, now gone once you changed the header/muffler. Kickstand was 2 pounds, front light to a number plate is 2 pounds, all the smog stuff is a pound, throw away the backfire screen. Ti axle bolts, swing arm bolt, stearing stem, three transmision gear rods.
  • knuklehead
Posted December 17, 2007 - 03:22 PM
Sidewinder has a Ti chain with teflon O ring's(BIG buck's) but it's like adding 5 hp it rolls so nice and is lighter.Get the fork's and shock set up for you(stock it's pretty soft spring wise) and it will feel lighter, but the big girl is still a BIG girl.
  • Denn10
Posted December 17, 2007 - 03:28 PM
ive seen mods to use a smaller battery off of a 450X, that should get you a few and you can relocate it under the seat. If you search thats been on here with great pics so you can see everything. With batt, battery box gone that should be 5-10 lbs. When i saw that they said it started fine with the smaller battery you just couldnt forget and leave the key on but as long as it starts your fine.
  • martinfan30
Posted December 17, 2007 - 03:36 PM
i havent heard of this on an R?
  • gialinn
Posted December 19, 2007 - 04:42 PM
look into narrower tires and different tire brands, different disk brakes. pull off excess plastic, aftermarket wheels. CR hubs tend to be lighter than aftermarket ones.
  • KAS
Posted December 19, 2007 - 04:50 PM
Whatever you do wont be worth the effort or replacement part cost.
The bike is heavy, getting rid of 10-15lbs wont matter much.
  • BWB63
Posted December 19, 2007 - 05:26 PM
10~15 pounds is huge!!! That is almost a whole spring rate. On the XR650R 15 pounds would make or break a major race. I would love to lose 15 pounds off my 680cc bike. I can feel the big difference when I take the Baja light off, going through the whoops at 70mph. If you let 5 pounds out of the front and back tires you could shed 10 pounds right there:lol:
  • scalejockey
Posted December 19, 2007 - 05:30 PM
A re-valve on the ol boingers really made mine feel lighter.In fact I like it over any light 250.It plows through the smaller to medium bumps.Where a lighter bike gets kicked all over.
  • stevenfallover
Posted December 19, 2007 - 06:03 PM
KTM 505....sorry had to say it.
  • weskc35k
Posted December 19, 2007 - 06:54 PM
Search for a guy with the handle RC30 he has taken a lot of weight from his pig.
The fork swap will lose about 4lbs,you can cut down the stator ,lose the case saver,the backfire screen,the overflow tank,grind the engine bolts,take off the heat shield ,the mid pipe mount can go,thermostat,Ti bolts,switchblocks swapped out and a heap more can be done.
  • Krannie McKranface
Posted December 19, 2007 - 07:27 PM
My guess at the cheapest way to loose the most weight.
Weights are estimated:
- CRF front fender (6 oz lighter) 35.00
- modified CRF rear fender ( 10 oz lighter) 35.00
- Smog (1 lb)
- Stock header and exhaust for Big Gun full ceramic coated. (6 lb) 450.00
- kickstand (3 lb)
- steel bars for alloy (9oz) 85.00
- top clamp for RSC racing ( 14 oz) 95.00
- stock tires ( up to 4 lbs for both) 170.00
- remove all wire capture brackets and hardware (6 oz)
- odometer ( 2.5 lbs)
- stock air filter/screen and cage for uni (6 oz) 29.00
- stock perches and levers for ASV billet ( 7 oz) 200.00
- upgrade handgaurds ( + 2 lbs) 100.00
- upgrade skid plate (+ 3 lbs) 90.00
- larger tank (+ 1 lb) (gotta have it) 200.00
- Ti bolt kit (2 lb) 350.00
That comes to under 10 lbs lost with the tank/skidplate/tank upgrades: The only way to loose REAL weight is to modify the Engine or the Frame or Wheels.
Don't use the Sidewinder Ti Chain: the 650 will stretch it in ten minutes.....
  • philipstjohn
Posted December 20, 2007 - 05:40 AM
This is the most detailed thread of a guy trying to shed some weight off the BRP
http://www.thumperta...highlight=RC30P
  • rdahl
Posted December 20, 2007 - 08:10 AM
Run less fuel?? :banghead:
Dido on it won't make much of a difference. It feels the same when i have .2 gallons or 4.2 in the tank....
  • Troy_Bell
Posted December 20, 2007 - 08:24 AM
Even better, replace that 10 pounds of air with helium. :banghead:
  • jk9270
Posted December 20, 2007 - 10:03 AM
Sorry, I'm not that good of a mechanic.:banghead:
  • jk9270
Posted December 20, 2007 - 10:07 AM
- Smog (1 lb)
- kickstand (3 lb)
2.5 lbs for the odometer. seriously.
Which thumper motor for a street tracker? by woz
  • Hot  29 replies
Washington
  • Hot  32 replies
Honda XR650L 2017
  • 0 reviews
  • Hot  35 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
