Engine stalls after initial water contact - ***?
3 replies to this topic
  • baysea
Posted December 17, 2007 - 12:19 AM
Hey all. Im riding a 98 WR400 and the engine stalls out after I hit the first puddle. No throttle response and it takes about 5 minutes before I can restart. Once restarted she will dive through any puddle no problems it's just the first one that gets her everytime. I've re-routed a couple of the carb hoses to the air box and checked wiring thinking it might be an electrical short but nothing doing. Any suggestions? Thanks
  • SJMC_DON
Posted December 17, 2007 - 11:32 AM
You said you checked electrical but my first suspect would be kill switch circuit either in the switch or somewhere else is getting wet and shorting.
Good Luck!
  • akiraone
Posted December 18, 2007 - 05:28 AM
hi,
I have similar problem like you after I hit the water even not so deep like to half haight of engine (to the half on of the clutch cover) my engine die I cant restart it to couple of minutes kicking or electric start.
My is wr450 '06
  • drtrcr400
Posted December 18, 2007 - 08:43 PM
Did you check the condition of your plug cap?
