Float adjusment hight on Edelbrock Quicksilver??
7 replies to this topic
  • krokodilen
Posted December 14, 2007 - 10:36 PM
Hi over there. Can any of you guys tell me the measure for my Xr 650r -00 i have just mounted this carb on my pig and i have a litle problem trying to make it run smoothly. I suspect that the bike leans out on higher rpms. It simply does not run at all, throttle wide open. Before i "click" the needle i want to be shore that the float bowl is not sucked dry and that the float hight is right. My Edelbrock Quicksilver is most certain one of lets say,,, 10 in Sweden :banghead: . So information is hard to come by. I could not find it in my papers or at the Edelbrock site either. And they have not retuned my E-mails that i send a few mounths ago.
I´m sorry for my bad English i´m not writing in this language very often and in tecnical terms it´s even harder.
Best regards from: Christer in Sweden
  • creeky
Posted December 15, 2007 - 07:10 AM
With the bowl removed, hold the float in the closed position and measure from the top of the float to the top edge of the bowl, it should be 17mm.
  • Agent2
Posted December 15, 2007 - 07:33 AM
Christer - what # needle are you running and what elevation do you ride at?
  • krokodilen
Posted December 15, 2007 - 09:53 AM
#E19 i think the elevation I´m not sure of yet have to check that. I bought the carb as a used part almost new though. The set up on my Xr is Yoshimura complete exhaust and twinair filter. It runs pretty well except from the hi-rev problem. I tested the bike against an Crf450 from about 20mph to 100mph an won that race by at least 20 meters.
I also have a bigbore kit 102,4mm 11:1 a restored and ported cylinderhead inkl hotcam stage 2 in my garage waiting to by mounted . That would do the trick.
Btw have you seen the Swedish Xr 650 Turbo with 100bhp on the wheel??
/ Christer
  • krokodilen
Posted December 15, 2007 - 09:55 AM
Ok thanks.
/ Christer
  • DREWBUSH
Posted December 15, 2007 - 05:19 PM
Do you have the quicksilver or the Edel Pumper carb? I assume they are similar. anyways I found a document for the pumper carbs http://www.edelbrock...650_install.pdf . this is current for the newer style pumper carbs, but it should give you a base to start from for yours.
  • krokodilen
Posted December 15, 2007 - 07:14 PM
I have the quicksilver carb, That pdf is good but it does´nt say anything about the float hight. Thanks anyway.
/ Christer
  • creeky
Posted December 15, 2007 - 08:04 PM
I had a Quicksilver on a '98 HRC628 that I had a few years ago, full Yosh exhaust, 19E needle in the carb. It ran best overall by adjusting for a slightly rich low end. Probably the fastest dirt bike that I have owned.
