01 yz426 snap
4 replies to this topic
  • 01_426f
Posted December 13, 2007 - 06:32 PM
does putting in both the intake and exhaust cam from Hotcams make the bike a lot faster or is it even noticeable? im looking at making my 01 yz426 a little snappier and faster (more 2 stroke-like) and was wondering if the cams make a difference. also, does porting and polishing the head do alot on these bikes?
  • felix4x4
Posted December 13, 2007 - 06:38 PM
Put a 450 ex cam in it. You will not be displeased with it. Also, its a lot more cost effective than the Hot cams.
Alot of the not being snappy on that motor is jetting and the ap timing on the carb. When I fixed that my bike ran totally different.
  • whyzee426F
Posted December 13, 2007 - 06:49 PM
I have the hotcam exhaust cam only...and noticed a difference after...more low end, a bit less hit. I later polished the intake port and I think it gave it more low end but have nothing to prove it.
Hotcams claims using both their cams yields increased torque and hp...and a mellower hit, I believe.
Whatever you do, make sure to change out that cam chain...50 hours or so and it'll be stretched, which seems to impact performance.
  • 642MX
Posted December 13, 2007 - 07:00 PM
If your looking for more snap, you should think about a 13.5:1 piston. The higher compression makes a bunch more mid-range. The Hot Cams will increase power across the board, they make the hit longer, not harder.
  • 01_426f
Posted December 13, 2007 - 08:04 PM
what about the zipty mod? so probably doing some porting and an 03 450 cam would do the trick?
Motocross
  • Hot  491 replies
  • Hot  33 replies
  • Hot  94 replies
