throttle sticking a little bit on my YZ450F???
9 replies to this topic
  • trippcobra
Posted December 13, 2007 - 04:17 PM
When I roll off of the throttle, it stays a bit above idle for a second or two. I don't think its in the linkage or actual throttle, is it maybe internal in the carb? any help appreciated. thanks
  • soudry
Posted December 13, 2007 - 04:33 PM
same thing here on a 08 yz450...
  • reed1
Posted December 13, 2007 - 04:43 PM
All bikes do that when there cold dont they??
Posted December 13, 2007 - 05:42 PM
That's called a "hanging idle", and it's caused by a lean condition at closed throttle, and/or an air leak.
Check your bike for a shrunk carb isolator (mount sleeve) (one that will no longer clamp down), or any other source of air leaks.
Attempt to adjust the idle mixture to correct the problem per the manual.
Check the float level.
Check the valve clearances. A hanging idle can be caused by tight intake valves. If you find this condition, and any valve requires a shim more than .10mm thinner than the original, you need a valve job.
  • soudry
Posted December 13, 2007 - 06:21 PM
by valve job you mean to adjust them?
Posted December 13, 2007 - 08:13 PM
No, that would be a valve adjustment. I mean the valves would need to be replaced at that point. You can try to run them longer, but you will most likely find that one or more of the ones that needed the big correction will be ot of spec again after 2 more hours or so.
  • reed1
Posted December 13, 2007 - 08:21 PM
2 hrs...........i would half to adjust them 3x in a day:excuseme:
  • BC3
Posted December 14, 2007 - 11:41 AM
Which means your valves are "HIGH TIME PARTS" and you need to replace them.....
  • racer 813
Posted December 14, 2007 - 07:00 PM
If either of you two are using u4 or the u4.2, it could be that little crystles are forming on the slide and it just needs to be cleaned!
  • todds924
Posted December 14, 2007 - 08:40 PM
The only problem you have is like Gray said. A lean condition. Being that these are new bikes the intake boot is not likely the problem. You should be able to correct it by turning out your fuel screw. If you have to go more than 2 1/2 turns, you need a bigger pilot jet. What gray means by needing to replace the valves is that if the clearances are that far off...tight..... then the valves are already "dished" and a valve job will need to be done. This is very common with the CRF's not the YZ's.
  • Hot  50 replies
  • Hot  38 replies
  • 5 replies
  • Hot  30 replies
