Headlight Wire Harness Repair
10 replies to this topic
  • Dust_Devil
Posted December 13, 2007 - 02:17 PM
Somehow my headlight wires broke in half, they broke off right at the connector, so I had to do a little more than just splice the wires together, I had to recycle the pin connectors. There was also some rub wear on other wires behind the number plate.
Use a small flatblade to remove the pin from the connector housing, be careful, these are not the type of thing you can buy at radio shack.
Use the flatblade to carefully bend the tabs holding the plug to the pin.
Leave about 3/8ths of an inch of wire attached to the pin and strip the insulation off, slide plug onto the new wire and attach the new wire to the pin.
Solder the new wire to the pin.
Slide the plug up to the pin, and reform tabs to hold plug, finesse is key here, dont trash anything.
Ok, here is the first layer of shrink wrap, it is the standard Polyolefin type, it stays flexible after shrinking, I will apply a second layer of PVC Shrink wrap to provide some durability and to prevent the new wires from twisting off at the connector.
One wire down one to go.
Ready to splice onto the main harness.
A couple other wires had insulation that had been compromised, I shrink wrapped them with the red shrinkwrap, you need to pull the wires from the connector housing, slide the rubber plug down the wire, then apply shrinkwrap. Shrinkwrap is much cleaner and more functional than black tape.
Splice the repaired connector and wires to the main harness, use solder to join the wires, shrinkwrap the individual wires then wrap the entire thing.
  • dezracerE
Posted December 13, 2007 - 03:59 PM
Double D
that almost happened to me on the starter button wires- caught it in time- solder and shrink wrap only.
Why do you run the light anyway- as a just in case for a long ride?
  • Dust_Devil
Posted December 14, 2007 - 07:06 AM
Double D
Yeah, just in case, we all know the stock light is a just getcha home type of thing, not really effective for night riding.
  • ds66
Posted December 14, 2007 - 09:28 PM
:busted: that deserves some gas, great work..:banghead:
  • Dust_Devil
Posted October 09, 2008 - 10:25 AM
Update... Repair failed!! ( after many many miles :D )
Im going to remove the stock connector, and replace with a different connector.
  • JohnnyAirtime
Posted October 09, 2008 - 10:38 AM
I can't vouch for the stock connecter... as i use these types for lighting (and ditch the stocker day one);
... in a worse case scenario, and you need more than 2 wire, you can use a flat 4 trailer connector. They work great, and are durable enough for dirt-bike abuse. I'll even take the wiring back down to "under the tank" area... splice in something of a little better guage and run it back up to the triple clamp area with a better connection method or something more durable for those "critical" wires.
I've had stock, and aftermarket companies (baja designs - dual purpose kit) wiring fail... and have learned too many times the hard way.
BTW DD... great little how-to. :D All but the TC sticker in the background. :worthy:
  • Dust_Devil
Posted October 09, 2008 - 10:55 AM
Where can I get a connector like that?
The Radio shack here just went tit's up.....
  • JohnnyAirtime
Posted October 09, 2008 - 11:08 AM
Damn Radio Hack.... the one down my street is carcassed, and I asked; "why are all the shelves so bare?" ... the gentleman stocking and moving stuff said, "we move things from store to store... items go to the store they are selling at" .... How dumb is that? I needed something in the BARE section!!
... I can't stand Radio Hack, but they do in a pinch.
TRY... Kragen, AutoZone, Pep-Boy type places. I know sometimes my Kragen has it all. But I also have one of those Warehouse type Kragens near. They've got near everything I need (as long as they don't ask; "what year is the vehicle? :D ) ..... :worthy:
  • Dust_Devil
Posted October 09, 2008 - 12:48 PM
Kragen and AUtozone here, I will look. That connector you posted looks perfect.
  • Dust_Devil
Posted October 09, 2008 - 02:17 PM
Score!!
  • JohnnyAirtime
Posted October 10, 2008 - 05:43 AM
Glad to hear!!! With your heat-shrink talent... that thing should be good as new in no time.
... I LOVE heat shrink!!
CRF450x overheating by smphealey
Dirt Bike   Make / Model Specific   Honda   CRF450X
  • 20 replies
Looking for crf 450x engine by scomorr
  • 4 replies
06 450x vs 05450r suspension by Jmac310
  • 0 replies
Engine Seize at Idle - '05 CRF450X by ZoogMX
  • 19 replies
Honda CRF450X 2017 by Chris.GVS
Honda CRF450X 2017
  • 0 reviews
