Which chain for my 07 YZ450f
11 replies to this topic
  • HMMRDWN
Posted December 12, 2007 - 02:59 PM
Which chain should I buy?
I have 2 choices that I am willing to buy in a combo with sprockets.
Renthal R1 Works and DID ERT 2.
I know that there are better chains than these out there but these are my 2 choices.
  • rmzRacer293
Posted December 12, 2007 - 03:12 PM
R1 is a good chain but i had to adjust it a lot on my 250f so on a 450 i think it might not be strong enough..... but who knows?
I havent used the ERT 2 but have only heard good things about it. :banghead:
  • BergArabia
Posted December 13, 2007 - 09:37 PM
there is another thread right here that could be useful.
I use a DID xring and it has worked for more than 100 hrs.
  • Wes Woodin
Posted December 30, 2007 - 08:50 AM
D.I.D. 520 VT "T" Ring
  • Ga426owner
Posted December 30, 2007 - 09:08 AM
I use the ERT2 chain. It works great for me
  • Slinkyman16
Posted December 30, 2007 - 03:18 PM
ive always have had good luck with d.i.d chains.. i just picked up the ert2 for christmas and planning on throwing it on for this weeks ride. ill let u know how it holds up to the 450.. i have the original ert on my 02 426. its been on there for 4 years and it just now in needed of adjustment.
  • yzfmerf
Posted December 30, 2007 - 04:53 PM
How are you guys running running chains so long? I thought you ere supposed to replace them when you changed sprockets? I want to try out the Protaper sprockets and go a little smaller and dont know if i really should replace the chain. It definitely does not seem to be stretching and the teeth on the countershaft sprocket look pretty good, just the aluminum Renthal starting to show signs of wear.
  • Slinkyman16
Posted December 30, 2007 - 06:58 PM
your soposed to change the sprockets with every new chain. but im a college student that dosnt have that much spare cash. so i only replace the sprockets if they show wear or if the teeth are starting to get curved. i take pretty good care of my chains and sprockets to get the most out of them. i clean/lube after every ride, and adjust. no matter how long it was. and i also clean all the lube off the sprockets to keep the grooves clean.
  • albertaguy
Posted December 31, 2007 - 07:30 AM
After running c500's for years you learn to appreciate the value of a quality chain, don't go cheap. I have ran renthal and d.i.d.'s top oring chains and both are solid. On my 450's after initial stretch/breakin I don't seem to ever have to toch them. I have never owned my 450's for more than 2 seasons so never wore out a set of sprockets but I attribute that to running a good chain and having it properly adjusted (see lots of guys running too tight). I have a whole box of stock 520 chains that have never seen a days ride.
  • Wes Woodin
Posted December 31, 2007 - 12:22 PM
Aint that the truth! Me too!
  • Ga426owner
Posted December 31, 2007 - 01:17 PM
great question....I have yet to fully wear out any rear Ironman SS sprocket. I am close on my 470 but she still has plenty of material on each tooth....I have had this sprocket and chain over 2.5 years....and that is why I only use these period end :banghead:
  • Wes Woodin
Posted December 31, 2007 - 01:49 PM
Yeah I am trying the twinring from renthal right now and so far I like it. I will tell you that I loved my Ironman Sprocket too. Never showed any wear.
  • Hot  79 replies
  • Hot  36 replies
  • 9 replies
  • 0 reviews
