Exhaust modification / Damper
2 replies to this topic
  • Snapper
Posted April 02, 2002 - 06:31 PM
I have just been through the posts on exhaust mod's and dampers - two questions?
has anybody actually modified the stock WR01 exhaust (or similar) - what changes did you make? I am considering shortening it, increasing the size of the core and putting a downturned end cap on. May not be as light as aftermarket but cheaper.
b)has anybody succesfully fitted a front mounted damper to a WR and retained the light/odo? Got Photo's?
  • skippy
Posted April 03, 2002 - 01:38 AM
Check out www.eatmydirt.com.au site. Forum. Under general.-Modified exhaust.
  • Snapper
Posted April 03, 2002 - 09:18 PM
Cheers Skippy,
seen that - a fella called roo-hunter has cut the end of his stock and replaced it with a removable end cap (40mm outlet) and left the internals alone. :D Suggests substantial mid range improvement.
Sounds like a good option - surely someone on TT has had some modification experiance here :)
I am buying a damper and can't afford a pipe as well :D
