Valve Inspection and Clearance Adjustment Limits
2 replies to this topic
  • BBrown626
Posted December 11, 2007 - 07:52 AM
Hi guys.
I am in the process of adjusting my valve clearances by replacing a couple shims. I previously had a shop do it (last year). The tech told me that one of the exhaust clearances was tight and he fixed it. I recognize that shim because it is a 180 rather than a number I can't get at the shop. All the rest are the original shims and therefore my baseline.
So knowing most of my baseline, how do I know when I should stop shimming and address the wearing of the seating surfaces?
The bike is an '04 YZ450F.
Brent
Posted December 11, 2007 - 08:57 AM
Since the hard nitride coating on the valve face is so thin (<.001"), almost any wear at the valve face means trouble. If you ever find a valve that needs a shim 0.10 mm smaller than the original, you most likely need a valve job. The giveaway will be when you ride the bike one more time and find that it needs to be reshimmed again afterward.
  • BBrown626
Posted December 11, 2007 - 12:36 PM
Thanks Gray.
  • Hot  47 replies
  • 5 replies
  • Hot  36 replies
  • 10 replies
  • Hot  38 replies
