2007 YZ450F Hour Meter
37 replies to this topic
  • jp765
Posted December 09, 2007 - 06:06 PM
Any ideas on a good location to place the meter and to wrap the wire.
  • crf-f crf-r trx cbr
Posted December 09, 2007 - 06:08 PM
on the frame........you yz guys don't have to clean the frame like us crf'ers
  • jp765
Posted December 09, 2007 - 06:13 PM
Thanks but i have been told that i cant just wrap the wire around the plug wire and it work is this true
  • motoscotty
Posted December 09, 2007 - 06:42 PM
Mine always worked like that.
  • steve_97060
Posted December 09, 2007 - 08:31 PM
yes, wrap it around the plug boot, then just zipty your hour meter to the throttle cables just above the radiator.
  • todds924
Posted December 09, 2007 - 09:30 PM
If your just going to rely on the sticky two sided tape to tape it to the frame thats a bad idea. I've had 2 of them fall off that way. I finally just drilled a tiny hole and put one screw in it along with the tape. Havent had a problem since. All the meters I've seen come with two small sheet metal screws and two holes to put them in. I mount mine on the right side of the steering head above and in front of the radiator.
Posted December 09, 2007 - 10:04 PM
You can't wrap th esignal wire around the spark plug wire because there isn't one on any YZ450. The wire has to be run around the plug boot (ignition coil).
An alternative to mounting them on the frame at all is to either tape it to your throttle cables, or mount on the inside of the air box. You can check when you clean your air filter, which you were going to be doing almost every ride anyway, right?
  • Wes Woodin
Posted December 12, 2007 - 08:25 PM
You drilled into the frame?
  • rexbond007
Posted December 12, 2007 - 10:08 PM
use silicone, stays put until u peel it off!
  • BBrown626
Posted December 13, 2007 - 10:28 AM
You need to wrap the wire around the exposed portion of the coil at the very top of the plug connector. With the plug properly connected, it is the last inch or so of the connector that sticks out the top. Wrapping it around the wire will not work on new bikes. I used Velcro to stick the meter on the steering head and added a loop of wire through the meter's screw hole and around an adjacent throttle cable just in case the velcro fails.
Brent
  • todds924
Posted December 13, 2007 - 05:44 PM
The key is mounting location............you don't wan't to go all the way through. i used a super short sheet metal screw and only used it in one of the two holes on the meter....also the 2 sided tape....I was really pissed after I lost the second one and this one is going nowhere.
  • cowboyona426
Posted December 14, 2007 - 01:27 PM
Here's what I did with the hour meter wire- tight wrap around the plug boot, then tight wrap with electrical tape. Looks nearly factory. For the meter itself, I zip-tied it to the throttle cables, it won't come off unless I want it to. Also, make sure you leave enough slack in the wire that you can still get the coil off if you need to change/check your plug or pull the head cover to check valves.
  • Wes Woodin
Posted December 15, 2007 - 02:56 PM
Looks Good!
  • Stupendous
Posted December 16, 2007 - 09:55 AM
I mounted my hour meter behind the number plate with industrial strength velcro. No problems so far.
  • BradThomas
Posted December 16, 2007 - 09:23 PM
What brand Hour meter are you guys using? I havent really looked into this and it seems I need to. I only have a few hours on the new bike. Probably less than an hour run time.
  • Stupendous
Posted December 17, 2007 - 08:06 AM
SenDEC. I picked it up at Sears.
  • todds924
Posted December 17, 2007 - 07:36 PM
If you look at the back of all the hour meters...99% of them are made by SenDec..... Dr D's say Dr D on the front but they say Sendec on the back.
  • cowboyona426
Posted December 18, 2007 - 10:20 PM
SenDec off of Ebay for $17 bucks. It's advertised as being for a lawnmower, but the only difference between it and other models is it is supposed to flash at some certain interval to remind you to change your oil.
  • Windseeker
Posted December 22, 2007 - 01:38 AM
My 2 cents... mmmm... better say 2 rubles? :banghead:
http://pics.livejour...rr/pic/00026xwd
  • steve_97060
Posted December 22, 2007 - 11:30 AM
That is how I have mine also...
  • Hot  36 replies
  • 0 replies
  • Hot  47 replies
  • 3 replies
