170s main jet
12 replies to this topic
  • naldz006
Posted December 05, 2007 - 07:44 PM
hey guys,
just changing the jets on my 650r. Going by the jetting page on the 'pig pen' a 170 main will be about spot on for me. I have a 170s jet that came with my wr. Is this likely to be any better or worse than the normal 170 jet?
cheers.
  • Maroast
Posted December 05, 2007 - 08:46 PM
hey guys,
cheers.
Hu, something seems a little funky here. So your WR has a keihin PE carb?
I have never heard or seen (i did a brief google search, and keihins website) of a main jet with a "s" designation... you have a hex main jet with an "s" stamped on it? doesn't make much sense.
Are you sure your not confusing the pilot with the main? there is such a thing a s a 70 pilot and a 70S pilot. Go back and double check...pull the main out of the XR and compare it to that 170s main (<--if thats what you reall have)
let us know what you find
  • naldz006
Posted December 06, 2007 - 12:56 AM
yeah i know it sounds odd. this is a pic of the jet. i'm guessing it will fit, ill put it in when i get a chance.
  • EddieTNT
Posted December 06, 2007 - 08:14 AM
That jet will definately fit your XRR carb. I have never heard of a 170S main jet. There are pilot jets for that carb that have an "S" designation after them, but I've never seen a main like that.
It isn't just the PE that uses that style of main jet. I know for sure that the PJ (2 stroke) and the PWK (2 stroke) also use the same mains. I am sure there are other model that do also. The float assembly from the PJs and PWKs also will fit the PE perfectly. My 650R's PE carb has a PJ float in it right now.
  • HawkGT
Posted December 06, 2007 - 10:52 AM
I've encountered S main jets. They've all been the stock main jets in Yamahas. As far as I can tell, Yamaha specs a main jet designated with S (i.e. "stock" ??) on some (all?) of their bikes. I believe they are identical to normally stamped main jets.
  • KAS
Posted December 06, 2007 - 12:17 PM
The 170S will work fine. All Yamaha stock main jets I've seen are stamped with an "S".
Its the same as a "normal" 170.
  • naldz006
Posted December 07, 2007 - 02:40 AM
yeh i put that jet in and its running better now. dont know what the old jet was.... had no markings on it.....bit dodgey. the bike still crackles a little bit under decelleration but it is better than it was. I might try a 172 main in it when i get a chance. it does 180kph now and still pulling a bit. pretty impressed really. hangs with the wr till 100 then keeps pulling. wish they still sold them over here so i could have got a new one.
  • motopsycho650
Posted December 07, 2007 - 04:31 AM
hey guys,
cheers.
An "S" jet is a half step larger than the jet of the same number without the "S". i.e. A 170S jet is a half step between a 170 & a 172.
I have never tried a "S" main jet, but either a 68S pilot, or 70S pilot is a must have in the 650R in my opinion. an S pilot jet will wake the low-mid range up and produce a major power difference.
my 650r has a stock engine, all the HRC un-corking parts, a cut out airbox cover, and a twin-air power-flow kit. I ride at elevations ranging between 5000-10000 ft. my current jetting is a 170 main, a 70S pilot jet, and the HRC needle set to the 4th notch from the top. I have played with many different jet combos over the last 4 years I've owned the bike. This set-up, at least for me, is by far the most power through the entire power-band.
P.S. Once I set up to this jet combo, I do not get de-acceleration pops any more at all.
  • HawkGT
Posted December 07, 2007 - 10:36 AM
An "S" jet is a half step larger than the jet of the same number without the "S". i.e. A 170S jet is a half step between a 170 & a 172...
I understand that the S pilot jets available from Honda have smaller emulsification holes which essentially reduce the size of the pilot air jet orifice. This in turn creates conditions that make an S pilot jet behave like a slightly larger jet then it's fuel metering hole would suggest.
Are you then inferring that an S main jet must also behave slightly larger than non-S main jets? Or have you actually compared the size of the fuel metering hole--S to non-S--and discovered the S is actually larger?? I checked my jets to try and make that comparison myself but I don't have a non-S 158 to compare to the 158S that I have.
I suppose I'm just a little skeptical that the difference between an S and non-S pilot jets supplied by Honda for the XR650R means the same thing for S main jets.
  • usarfire
Posted December 10, 2007 - 08:43 PM
I just put a 170 main in my xr600 96 and it goes like a rocket but had to go 4 turns out to get it to stop popping on deceleration. Going to work on the pilot jet tommorrow
  • Billahjack
Posted December 10, 2007 - 11:50 PM
A 170 Main sounds small on an uncorked XR unless you are at fairly high altitude.
  • weskc35k
Posted December 11, 2007 - 01:05 AM
A small amount of popping on decel is a good thing,if it doesn't it's too rich.
When the throttle is chopped and the slide closed this when the bike should burble a bit.
  • KAS
Posted December 11, 2007 - 07:32 AM
You should probably run a larger pilot if you're 4 turns out on the fuel screw.
Honda XR650L 2017
  • 0 reviews
Honda XR650L 2016
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  28 replies
  • 22 replies
