06 450 crankcase crack
12 replies to this topic
  • SawDustMan
Posted December 05, 2007 - 07:18 PM
Have an 06 with a cracked right case. For some reason you have to buy the set of left and right from all the places I have checked. Why? Are they machined to match? Could I get a used right off ebay and use it with my good left side?
Thanks,
Cy
  • tnl
Posted December 05, 2007 - 07:25 PM
Do a search on your question.
  • todds924
Posted December 05, 2007 - 08:26 PM
Thanks,
Cy
They are machined as a set.
  • SawDustMan
Posted December 05, 2007 - 08:37 PM
Thank you todds924, I suspected as much but hoped it wasn't true.
tnl, which is harder, replying with a quick answer or replying to tell me to search?
Cy
PS I did search through about 5 pages about crankcase problems without finding the answer. Only questions about welding cracked cases.
  • todds924
Posted December 05, 2007 - 08:39 PM
Cy
He didn't know the answer.
  • tnl
Posted December 05, 2007 - 09:30 PM
Cy
Now that I have more time to help (I hope) here is my search from "cracked case: http://www.thumperta...015#post5536015 Review master Gray's comment (2nd post). There's alot of great info. in there from Gray and others at my expense :thumbsup:
Unfortunatley I did and it's gonna cost me about $1900 with labor :busted:
Posted December 05, 2007 - 10:19 PM
To elaborate, crankcases are made in two steps. The center joint and the threaded holes used to bolt them together are done first (other operations may be done concurrently), but none of the shaft bores are cut. Then, the cases are bolted together and the bores for the shafts that run through both cases are bored while the cases are mounted in the same jig fixture. This ensures that the axis of all the bearing pockets are square with each other from one side to the other, and each is parallel to the other shafts.
With modern machining techniques, it would actually be possible to precisely do this job one case at time, but it is still far simpler to line bore them as a set.
  • SawDustMan
Posted December 06, 2007 - 06:28 AM
Thank you, one more question.
The yamaha owners manuals I have had in the past (02 426) went though a complete teardown of the motor. Is that still the case or do they now have a separate service manual?
Thanks,
Cy
Posted December 06, 2007 - 07:16 AM
Both. The owner's manual is still a decent shop manual, but they do have a better one yet for the shops.
You can download one here:
http://www.yamaha-mo...ice/manuals.jsp
  • srfdwg2
Posted December 06, 2007 - 06:13 PM
What are you wanting to spend on engine cases for 06/07?
  • srfdwg2
Posted December 06, 2007 - 06:16 PM
p.s. how are these people cracking the cases?Derailed chain,or snapped chain?
  • SawDustMan
Posted December 06, 2007 - 08:23 PM
I this one broke around the oil drain bolt. Looks like it was hit by something.
  • tnl
Posted December 06, 2007 - 09:23 PM
Masterlink came off on mine. Just got a final settlement from insurance today for $1900.
  • 0 replies
  • Hot  50 replies
  • 5 replies
  • Hot  36 replies
