Quick Tip:Inside Header 6mm AllenBolt-stripped? No Problem....
3 replies to this topic
  • yz250o2
Posted December 03, 2007 - 01:30 PM
If the inside 6mm Allen head is stripped on your yz450 from taking the header on and off constantly.....use a T40 Torx driver....works with NO slips on the rounded out allen bolt....
Just in case you guys run into that horrible situation.
  • nap__kxf
Posted December 04, 2007 - 05:55 AM
i'll have to get one of those...damn dr.d header is right in the way of my oil cover :thumbsup:
Posted December 04, 2007 - 06:52 AM
i'll have to get one of those...damn dr.d header is right in the way of my oil cover :busted:
So? Loosen the 12 mm hex nut on the outside, and use a tire iron to flex the pipe up enough to draw the top bolt out. :thumbsup: No reason to disturb the Allen bolt.
  • sam250
Posted December 07, 2007 - 11:23 AM
I learned this trick the hard way
