Wave Rotors?
9 replies to this topic
  • sharktaco
Posted December 02, 2007 - 08:27 PM
Has anyone used these wave rotors? Ive never seen a XR650L with them.
http://cgi.ebay.com/...0127820192&rd=1
  • Krannie McKranface
Posted December 02, 2007 - 09:01 PM
Galfer rotors are top quality. Improves braking modulation (feel and control). Does not shorten stopping distance.
  • ghrati ghoti
Posted December 03, 2007 - 07:56 AM
I have the rear wave rotor on my L, the front one they list for the L does not fit.
Looks cool, but doesn't work any better than the stocker.
  • Albie
Posted December 03, 2007 - 10:21 AM
The big pluses for wave rotors is that they clean out quickly and disapate heat better.
  • 2000dr650
Posted December 03, 2007 - 10:53 AM
hadem both...looks cool, thats it...big waste of money
  • dmvmechanics
Posted December 15, 2007 - 11:01 PM
do you think it would be worth it for my xr650r supermoto?
  • sharktaco
Posted December 16, 2007 - 08:42 AM
Well, I should have listened to you. The front doesn’t fit. I’m looking for a FRONT wave rotor for a 2007 Honda XR650L with stock hub/rim. For some reason, the front rotor for this bike, as listed in the Galfer catalog part # DF017, does not fit. Anyone aware of any other rotor that will fit?
Posted December 16, 2007 - 07:18 PM
What do you mean it 'does not fit'? Most Galfer rotors are oversize, and need a caliper reloator bracket.
  • sharktaco
Posted December 16, 2007 - 09:44 PM
The bolt pattern is different. The front Galfer bolts are spaced about 3 3/4 inches apart, as measured from the center of the bolt holes. The holes on the stock rotor are closer to 5 inches apart. The diameter of the rotor itself is correct, as is the thickness. The rear rotor fits fine.
  • Denn10
Posted December 17, 2007 - 08:33 AM
oversized is what makes the big difference, save money from buying a stock size and get a larger rotor kit.
