Oil Leak
6 replies to this topic
  • mvm450
Posted December 02, 2007 - 09:48 AM
Have an 07 450f. This past weekend at the track I noticed oil dripping out of an overflow hose coming from the top of the valve cover. It only noticed it when I stopped to take a break. It would only drip for about 15-20 seconds then it would stop.I don't see any oil spray on the bike, so I don't think it's coming out while I'm ridding, could be wrong.I checked the oil level and it was fine. Is this something that is normal, is ths over spray, should I be concerned? I never noticed it before this past weekend. Need a little help.
  • 642MX
Posted December 02, 2007 - 12:56 PM
Sometimes the YZF's will blow a little oil out when they are ran hard or over-filled with oil. Its normal. :thumbsup:
  • blue9red9
Posted December 02, 2007 - 04:26 PM
Normal, mine does drip sometimes. There are a couple threads about that tube and how it should be rerouted into the airbox. It is proposed that under the right conditions, it can suck stuff into the engine. One guy even claimed it ruined his engine due to sand being sucked into the tube and then the head. I rerouted mine just for safety as it was cruddy at least up 5 inches or so from the bottom which says, some sucking of dust occured.
  • mvm450
Posted December 02, 2007 - 05:32 PM
Hey thanks alot for the info. I can rest easy now.
  • todds924
Posted December 02, 2007 - 08:16 PM
Nothing to worry about. This happens when you overfill!
  • DRTYHRRY
Posted December 03, 2007 - 02:18 PM
Does anyone overfill to the point that oil will not drain to the crankcase as normal?!?!!
Posted December 03, 2007 - 03:35 PM
Overfilling won't prevent the oil from draining to the crankcase after feeding the lube circuit. What it does is prevent the oil from being cleared out of the crankcase. This happens when there is so much extra oil that there isn't room for all of it in the tank (frame or built-in), and the excess is pushed back into the engine via the pressure balance line.
Overfilling to this extent normally occurs when one either fails to drain both the crankcase and the tank, or when one fails to run the engine before checking the oil level, which will incorrectly indicate that the engine oil level is low.
Overfilling an '03-'05 is a little more difficult than others, because the tank has a fairly large excess of capacity. These and the '98-'02 models will hold around 2 qts before they start acting like this, and since the steel 450's use only 1.2 qts, and they are filled at the crankcase, they can take over half a quart extra, and it's easier to notice that there is already a lot of oil in the crankcase, too. An '06-'08 model will take very little extra before it starts raising the oil level in the crankcase.
  • Hot  47 replies
  • Hot  113 replies
  • 9 replies
