XR600 Stator
3 replies to this topic
  • pd10913
Posted December 02, 2007 - 03:04 AM
I'm just about to throw a new Risky Stator in my 98' XR600 as a straight swap for the stocky stator and I just want to know when fitting, does it bolt straight in the same way the old one came out or do you have to line anything up timing wise, the engine/crank has been moved since removing the old one.
Any info is appreciated.
  • daddyk
Posted December 02, 2007 - 08:14 AM
Mine just bolted right on. Make sure you seal it where the rubber grommet passes the wires thru the case or you'll have an oil leak. Follow the diagram for using the extra power however you want and and you're set.
  • cleonard
Posted December 02, 2007 - 10:05 AM
It just bolts in. The timing sensor for the ignition is on the other side of the crank. The stator only makes power for the headlight and the ignition. Like daddyk said use a little silicone rubber or similar to seal the rubber grommet that has the wires.
  • pd10913
Posted December 02, 2007 - 12:29 PM
Excellent, thanks for the info guys.
Honda XR650L 2017
  • 0 reviews
  • 22 replies
  • Hot  35 replies
  • 17 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
