Rebuilding my front brake master cylinder
1 reply to this topic
  • PatrickM
Posted December 02, 2007 - 02:46 AM
I have some brake fluid on my handbars so I figured its about time to rebuild my Front brake master cylinder.
My question is....I purchased a kit from my local shop that was to replace the actual master cylinder and all of the seals but is there anything lese that you all think should be replaced while the front brake system is taken apart????
Also....what's the best brake fluid to use for a dirt bike???
Thanks for the help!!!!!!
Patrick M.
  • Dirtbiker05
Posted December 02, 2007 - 05:24 AM
try just replacing the master cylinder with all of the seals on it first. if it still leaks id say you would have to replace the copper washers on the bolt that holds the brake line onto the resevoir. use some dot4 brake fluid. hope this helps. good luck.
  • Hot  36 replies
  • Hot  47 replies
  • Hot  50 replies
  • On January 15, 2017
  • 10 replies
