Powerbomb question
10 replies to this topic
  • SID013
Posted December 01, 2007 - 11:19 PM
I am looking at getting some more low end power for my '06 WR450 & presently have a DRD slipon exhaust with the standard WR450 header. Question is will a FMF Powerbomb or Megabomb header suit the DRD slipon or do I have to buy a complete FMF system? Also are they really worth the bucks.
Looking for some feedback.
Cheers from Oz
  • surfer
Posted December 02, 2007 - 05:25 AM
The fmf powerbomb will fit the stock pipe so I believe it should fit the Dr D. I ran the powerbomb with a stock uncorked pipe on my 04 and there was a noticable difference in power.I just put a fmf q4 on it and will check it out today. Ed Scott
  • clark4131
Posted December 02, 2007 - 09:10 AM
I run a Powerbomb with a Dr. D. There is no fitment issue and I love the setup...SC
  • redswr
Posted December 02, 2007 - 05:29 PM
+1 for the power bomb... got one on my 99 and i noticed it pretty good.
  • 123BigcoopDawg576
Posted December 02, 2007 - 08:13 PM
SC i am running the Dr. D as well but with a stock header...what did you notice when you added the powerbomb oh and can you do an oil filter change with out the header needing to be moved?
  • clark4131
Posted December 03, 2007 - 06:35 AM
I've had the Powerbomb on since day one. The Dr. D is my third can. Honestly, I can't give you an opinion on just the header, but the whole setup is great. I've got no issues with clearance during an oil change, and I even have an E-Line carbon fiber heat shield on it that never comes off...SC
  • SID013
Posted December 03, 2007 - 01:01 PM
Many thanks for the responses guys, I didn't consider the clearance ussies for oil filter changes but Clarke answered that one for & also a heat shield. Great info, No just gotta cough up the dollars for the Powerbomb.
Thanks again.
Cheers from Oz.
  • dmoney1074
Posted December 03, 2007 - 01:47 PM
+1 for the powerbomb.... really increased power from top to bottom! Its worth it man.
  • SJMC_DON
Posted December 03, 2007 - 03:58 PM
As long as your going power bomb, I would go with the Stainless Steel version. Depending on your terrain and riding style - I was always denting and smashing the OEM Ti unit. The SS / SX Power bomb appears to be way more resistant to denting:thumbsup:
  • SID013
Posted December 04, 2007 - 02:17 AM
I was going to go with the SS header anyway as being an old bloke I occassionally fall off. :busted: Thanks for the heads up.
:thumbsup:
  • trailordune
Posted December 05, 2007 - 10:01 PM
You will be very happy w/ the powerbomb, sx version for low end torque. I put this headpipe on for that very reason and got just what I hoped for, more chug on bottom and a stronger pull through the mid into the top. The top end definitely drops off earlier compared to the stock headpipe though.
